a/c problem?
#817550
06/08/07 05:28 PM
I have an 87 4Runner SR5. Until yesterday my a/c always blew cold. You know how you push the green a/c button and feel the power surge from the engine? Well yesterday I hit the button, There is now power loss at all, and it blows warm air. Any quick fixes?? or is my a/c bought the farm?
Re: a/c problem?
[Re: skoyboy35]
#817551
06/08/07 08:12 PM
Perhaps you need to top off the refrigerant, if the pressure gets too low the limit switch won't allow the A/C compressor to kick on. But you do have more power now with the A/C button pushed <img src="/forums/images/graemlins/pfft.gif" alt="" />
Dave A. 88 P/U lots of mods 95 4Runner on 33's with a Detroit Couple of mountain bike's rolling on 26's.
Re: a/c problem?
[Re: OFFRD88]
#817552
06/08/07 10:10 PM
The "more power" is probably the A/C idle up valve kicking in, it bumps the idle RPMs up a few hundred RPM with the A/C running.
Re: a/c problem?
[Re: OFFRD88]
#817553
06/08/07 10:10 PM
Also check the A/C Fuse, located behind your glove box.
Start simple (and cheap)
Re: a/c problem?
[Re: Staceman]
#817554
06/09/07 03:12 AM
make sure that if and when you buy a recharge bottle, make sure to get the R134 conversion kit. the one i bought was super easy to use and was pretty cheap
V6 pickup 4x4, 385,000 miles and still ticking
Re: a/c problem?
[Re: walktastic]
#817555
06/09/07 04:00 PM
assuming it's got 134 in it already?
msg - '87 xtracab
Re: a/c problem?
[Re: yodta]
#817556
06/09/07 05:34 PM
Thanks for the responses. I took it to a local Auto Zone and the manager said that I was out of freon. He suggested that I get it converted over to the new R?? something or another. He also said that he could do the conversion for me for $200.OO which also consisted of pumping out the old stuff stuck in the system. He is the store manager and he says he has converted over 30 toyotas already. Should I trust him or should I go find a place that will fill it back up with freon??
Re: a/c problem?
[Re: skoyboy35]
#817557
06/10/07 08:27 AM
You're in Vegas? I'd find an AC specialty shop if I were you. also look at the info here: http://www.ackits.com/Dave
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6245 MB (Peak: 0.7063 MB) Data Comp: Off Server Time: 2026-06-07 11:38:15 UTCValid HTML 5 and Valid CSS
