How to get the best power increase? #817561 06/08/07 05:42 PM
0
00grandRodriguez Offline OP
Im looking to get a cold air intake and performance exhaust for a 4.0 grand cherokee wj are there any suggestions for the best increase... And are there any other ways to gain power...
2000 grand cherokee wj 3" iron rock, possibly adding 2" spacers...32" ssr...2 12" 1000w competition pioneer subs...2000w nitro amp
Re: How to get the best power increase? [Re: 00grandRodriguez] #817562 06/08/07 05:58 PM
BigJim Offline
Only regearing your axles will attain more power! Increasing the rpm at a given speed is what you should be after..
Changing the intake or (and) exhaust will do nothing for horsepower gain at low rpm.
If you have oversized your tires you should also undersize your gears.
These things ain't sport cars they are designed for off road use.
One of the WORST additions would be a supposedly "cold air intake" Leave the wonderful stock intake system on there for long engine life.
There are lots of folks that will SELL you something...all to no avail, you will simply have spent your money for no gain.
Re: How to get the best power increase? [Re: 00grandRodriguez] #817563 06/08/07 08:52 PM
BobRowe Offline
I agree with BJ. You don't get something for nothing in this world, particularly the world of Jeeps. Most add-ons only help, if at all, at the high end of the rpm range, which you will hardly ever use off-road. In fact, some of the things that people ordinarily do to increase the horsepower of an engine at high rpm will kill it at low rpm. For example, racing cams installed in an off-road machine will ruin it's low end grunt, which is want you want when four-wheeling. Some exceptions to this are desert racing, sand drags, and hill climbs, which few of us do.
Re: How to get the best power increase? [Re: 00grandRodriguez] #817564 06/09/07 01:08 AM
shimniok Offline
I don't know if I entirely buy the cold air intake concept... I guess it could help a tiny bit in theory. If you ask me, it is probably the case that hte stock exhaust is somewhat restrictive. You want to try and reduce restriction without significantly raising the power band rpm range... so in other words, a 3" exhaust = bad. <img src="/forums/images/graemlins/smile.gif" alt="" /> But you might think about a freer flowing muffler and catalytic converter. I base this on my own experience with AMC V8.
The only thing is, if flow is too free, the computer may not be able to 'learn' the right mix (ie, richen it up enough). That is one PITA with the computerized vehicles as they aren't as easy or cheap to retune as carb. I agree, gearing will help if you have increased tire size. If gearing is already optimal, Just going with lower gears won't necessarily help unless the power band is altered. Also tire and wheel weight reduction will help.
I guess I should've first asked... what specifically are you trying to fix? Off-the-line acceleration? WOT acceleration? Part throttle? Hwy ? Hill climbing?
Michael
1986 Jeep Grand Wagoneer - "Troubled Child"
Re: How to get the best power increase? [Re: 00grandRodriguez] #817565 06/09/07 01:39 AM
cuervo25 Offline
if you want power the best and only ways to get it is stroaking your engine and regearing. cold air intakes (aftermarket) do nothing but suck oil and dirt into the throttle body. I had my share of that then trashed it.
Re: How to get the best power increase? [Re: cuervo25] #817566 06/09/07 05:31 PM
0
My big problem is when i have a trailer on the jeep with just a fourwheeler and i cant hardly tow, feels like a house behind me... also without the trailor take off is a drag
Re: How to get the best power increase? [Re: 00grandRodriguez] #817567 06/09/07 05:56 PM
BigJim Offline
You describe a need for GEARS! What size tires are you running? With 31/32's on there even with a V-8 engine those 3:07 gears would bog down on the hiway with a small trailer..
It is all about keeping the rpm up in the power range of the particular engine. Get the proper gears and a whole new world will reveal itself to you.
Re: How to get the best power increase? [Re: BigJim] #817568 06/09/07 06:48 PM
0
im running 32" and i have the I6
Re: How to get the best power increase? [Re: 00grandRodriguez] #817569 06/09/07 08:15 PM
BigJim Offline
Yep! You need gears.
Re: How to get the best power increase? [Re: 00grandRodriguez] #817570 06/09/07 08:45 PM
fred1980 Offline
4.10's and 32's would be ideal and put you right back around stock performance for your jeep. If you plan on going any bigger than 32's OR you want a bit more grunt towing or accelerating you should get 4.56's but your Highway RPM's would be pretty high if you stick with the 32's (around 2800-3000 RPM's going 65).
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-07 06:56:39 UTC
