07 4runner v8 - where to buy a performace chip? #817576 06/08/07 06:48 PM
kens Offline OP
07 4runner v8 - where to buy a performace chip? A coworker is looking for more power in his new 07 4runner v8. Is there a plug in chip or does one need to send in the ECU? Thanks for the help!
Re: 07 4runner v8 - where to buy a performace chip? [Re: kens] #817577 07/03/07 03:12 PM
azrain Offline
Edited thread, booted out spammer, reply below originally from Greg_Canada:
Chips for toyota's dont work like that.
What you need it a tuner, in import cars, you cant just replace the chip, you need to work with the stock computer.
www.URDUSA.com makes products for the 4.7l v8.
Re: 07 4runner v8 - where to buy a performace chip? [Re: azrain] #817578 07/03/07 04:38 PM
G
Greg_Canada Offline
Sorry let me edit my post...
What you need is a tuner, in import cars, you cant just replace the chip, you need to work with the stock computer.
www.URDUSA.com makes products for the 4.7l v8. For a N/A motor i believe you need a MAF calibrator so you can tune in your A/F ratio's. You'll also need a wideband o2 sensor to monitor the A/F ratios.
With a good tune on a stock motor you can usually gain 10-20hp, but if you already have headers, exhaust, intake, etc, a good tune will net you close to 30hp. Best place to look would probably be tundrasolutions.com because their trucks have the same motor yours does. I personally have only looked at a site a few times and i hear the people there arent near as freindly as the ones here. Good luck.
89 4Runner
Re: 07 4runner v8 - where to buy a performace chip? [Re: Greg_Canada] #817579 07/05/07 06:14 PM
kens Offline OP
Thanks for the info! I will let him know. Again Thanks!!!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6015 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-10-22 12:14:09 UTC
