what gears should i run? #817613 06/08/07 11:09 PM
hoki06 Offline OP
im looking at new gears to get some of my power back but im not sure which ratio. ive got 32" tires and will have 33" tires whenever these run out which will be a while. should i get the 4.10 or 4.56? and how do i tell what axel i have both front and rear to see if i need a new housing? thanks
Re: what gears should i run? [Re: hoki06] #817614 06/09/07 12:16 AM
BigJim Offline
You prolly have the 3:07 gears in there now. If so you WILL need new carriers for the gears. I am a fan of too much gear rather than to little. I'd be going after the 4:56's if it were me.
Re: what gears should i run? [Re: BigJim] #817615 06/09/07 03:52 AM
hoki06 Offline OP
thats what i was thinking. what would i have to get for a new carrier? a whole new axle, which would be great because i think i have a dana 35, or something else?
Re: what gears should i run? [Re: hoki06] #817616 06/09/07 03:47 PM
4x4Wire Offline
The "carrier" is the holder for the spider and ring gears that fits inside the differential.
If you are going to re-gear and need to change the carrier, I would recommend that you upgrade to a full-floater axle kit to eliminate the D-35 C-clip.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-20 18:15:14 UTC
