dana 20 #817685 06/09/07 07:42 AM
jruth69 Offline OP
i have a stock 1977 cj-7 three speed. I just found a newer/rebuilt engine with a 5speed transmission i was wondering if anyone knew if it would fit or would i have to buy a transfer case adapter <img src="/forums/images/graemlins/confused.gif" alt="" />
amc 20 *DELETED* [Re: jruth69] #817686 06/09/07 05:30 PM
jruth69 Offline OP
Post deleted by jruth69
Re: amc 20 [Re: jruth69] #817687 06/09/07 08:26 PM
BobRowe Offline
I assunme you mean a Dana 20 transfer case? The AMC 20 is a rear axle.
Fit depends on the particular transmission you have. I suggest that you find out the designation fo the particular tranny you're talking about, and then call Advanced Adapters and find out if it will fit direct, or if you will need an adapter.
Re: amc 20 [Re: BobRowe] #817688 06/10/07 04:15 PM
superdawg Offline
Dana 20 t case has the same bolt pattern as a Dana 18 and scout dana 300 case.
D20 is a very good strong t case, but lacks low enough ratio in low range.
The trans you have (provided it is out of a later model CJ) will work with a Jeep dana 300, but not your d20.
The biggest problem is that the T150 tranny you have is stronger than the 5 speed (t-5) anyday. so...the best solution for reliabe strong upgrading is to go with a t-18 4 speed, and keep your d 20 case or really upgrade and do a t 18 with a d300 behind that. Call Mitch at RMH Transmissions 303-808-1268 he can fix you up.
SD
Re: amc 20 [Re: superdawg] #817689 06/10/07 07:35 PM
jruth69 Offline OP
yea well i think im gonna get it anyway cause my motor is shot almost runs like ***** nbut yea i got the offroad shop here to order me a dana 300
Re: amc 20 [Re: jruth69] #817690 06/11/07 12:29 AM
superdawg Offline
The t5 is junk, beware. This is the time to upgrade to a better tranny. Afterall you will be getting new driveshafts to go with the t5, sooner or later you will be doing it again.
SD
Re: amc 20 [Re: superdawg] #817691 06/11/07 08:15 AM
jruth69 Offline OP
yea i know nbut i am gonna try it with the three speed tranny then try the 5 speed to see wat i like best <img src="/forums/images/graemlins/mrt.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6172 MB (Peak: 0.6906 MB) Data Comp: Off Server Time: 2026-06-17 13:24:49 UTC
