motor swap #817692 06/09/07 01:40 PM
jameswest Offline OP
i havent posted here since 2000, had to get a new user name and all...anyhow
i have a '00 rodeo ironman edition with a bad motor (V6)...anyone know anyone who might have a wrecked rodeo or just the motor around VA?...also, what are your thoughts on how much bread is an exceptable amount to dump getting this truck on the road?
thanks
'97 K2500 DD/tow rig
'79 scout rock buggy
'08 silverado Z-71 work truck
'07 mazda 3 5 door wife's ride
Re: motor swap [Re: jameswest] #817693 06/09/07 08:58 PM
BigSwede Offline
Howdy. Can't hurt to check with Matt at Independent4x, in Richmond...he might know of a donor vehicle.
Otherwise, I would contact Jerry Lemond in Georgia jlemond@bellsouth.net
He often parts out Isuzus.
Serenity now!
Re: motor swap [Re: BigSwede] #817694 06/10/07 12:46 PM
yeah... i work w/matt @ indy4x (part-time)...i also checked with the guy in georgia (or rather had Joe D. check); he had a low-mileage lower half that i could swap heads onto, but thats more work than i want to get into...
thanks
Re: motor swap [Re: jameswest] #817695 10/03/07 07:22 PM
alright...i got my new motor in and my wife has been driving the truck for a few weeks. here's the issues:
odb code for random/multicylinder misfire. if i clear the codes, it runs well...after a while it starts to accelerate inconsistantly and the code comes back...its like the throttle's not responsive...additionally, when the code comes back the transmission starts shifter really hard and acts like its slipping b/w 2nd and 3rd under heavy throttle...
thoughts?
also the sending unit in the fuel tank is bad...do i need a whole new pump (like the dealer says?) <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: motor swap [Re: jameswest] #817696 10/04/07 05:08 PM
HCMP Offline
Have you checked the TPS?
Re: motor swap [Re: HCMP] #817697 10/05/07 08:59 PM
nope...how would i check it?...what does it look like/where is it?
Re: motor swap [Re: jameswest] #817698 10/08/07 03:37 PM
matthew Offline
tps = throttle position sensor
this particular rodeo that James ownes has the "drive by wire" throttle set up on it.
the issues it has def seem to be electical in nature.....pretty frustrating.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: motor swap [Re: matthew] #817699 10/09/07 03:34 AM
Bigpoppax2 Offline
No you don't need a whole new fuel pump to make your fuel gauge happy.
Here is a write up I did a while ago with part numbers and everything. You may need to get your computer reset for the thing to start working. Mine started working right away, but others have needed the reset.
Joe
Re: motor swap [Re: Bigpoppax2] #817700 10/09/07 03:47 AM
thanks...i got the info for that on the planet...really not as much a concern as the run issue...but i do appreciate the help
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6268 MB (Peak: 0.7295 MB) Data Comp: Off Server Time: 2026-06-21 19:01:20 UTC
