USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO #817720 06/09/07 05:40 PM
W
wlkn89swbMONTY Offline OP
MY 89 LS 2DOOR V-6 AUTO RUNS FINE, BUT HAD AN 87 4 CYL AUTO W/ BAD ENGINE OFFERED TO ME FOR $500.00. WHAT PARTS CAN I TAKE OFF AND SAVE TO USE ON MY 89? GLASS, DOORS, HOOD, FENDERS, SEATS...
BONE STOCK 89 MONTERO LS V-6 AUTO SWB, EVERYTHING WORKS, INCLUDING THE HEADLIGHT WASHERS, AND THE R-12 BLOWS 45 DEGREES. ORIGINAL OWNER WITH 123,350 MILES.
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: wlkn89swbMONTY] #817721 06/09/07 05:53 PM
Most everything in the interior can be used, the primary differences between the years being drivetrain parts.
If you don't use all caps, it doesn't seem like you're yelling. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: rxinhed] #817722 06/09/07 06:24 PM
W
Thanks for the reply. I was hoping the drive line parts were. I can swear, I read in this forum, that from the tansfer case to differentials were identical. the only interior part I noticed is the instrument cluster(Gauges and indicator lights) If what You said is true, I'll just turn around and sell the 87 for parts. $1,000.00
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: wlkn89swbMONTY] #817723 06/09/07 06:49 PM
sparkem Offline
4cyls use smaller diffs, I think smaller outputs on the t case.
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: sparkem] #817724 06/09/07 07:16 PM
W
O.K. Fellows, just found out, the 87 is a Raider. I don't want to be figured as a $$$ Grubber, but I will still buy it and sell it to make a couple bucks. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: wlkn89swbMONTY] #817725 06/09/07 07:32 PM
sparkem Offline
Raider is the exact same thing as a montero.
Re: USABLE SWAP PARTS FROM 87 4CYL AUTO TO 89 V-6 AUTO [Re: sparkem] #817726 06/09/07 07:47 PM
justice Offline
yea you should be able to use most of the interior and exterior trim body parts. Diffs are smaller on the 4 cyl models. A V6 auto SWB with headlight washers? truly a rare beast you have yourself there. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.025s Queries: 15 (0.020s) Memory: 0.6166 MB (Peak: 0.6940 MB) Data Comp: Off Server Time: 2026-11-04 20:02:05 UTC
