Re: Things behind front bumper [Re: bombardj1] #817786 06/11/07 03:53 AM
kiarazy Offline
i cut mine off to put new bumper on its just a piece of steel hit it all you want. <img src="/forums/images/graemlins/nana.gif" alt="" />
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: Things behind front bumper [Re: kiarazy] #817787 06/11/07 06:02 PM
Dave Scott Offline
the bumpers i made mounted to that, plus the front most body mount plate (top and front side). it's pretty sturdy, but i wouldn't trust it alone, to hold a winch under a heavy pull or even to hold together in a wreck. and it's a good place to bolt a bumper on. i would leave them unless you plan to weld a custom bumper to the frame (in other words, something stronger than just bolting one on).
Re: Things behind front bumper [Re: Dave Scott] #817788 06/12/07 02:30 AM
Axe Man Offline
Kia Moderator Emeritus
I'm not sure about years prior to 1998 but I can tell you that from 1998 - 2002 there are NO airbag sensors in the front bumper assembly. All the sensors are contained in the ADU which is located under the front console. There are pendulum type sensors which sense impact.
But again, that's for 1998 and newer. I don't know about prior years and if you DO run into sensors in the front bumper I would leave them alone.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Things behind front bumper [Re: Everet] #817789 06/13/07 12:10 AM
logansportage Offline
Everet,
These are the crumple zones for a front end collision. They crumple absorbing and dissipating energy.
When I did my body lift, I cut the front section off of these crumple zones. The section on the top rite at the point where they neck down and then neck back out. In the valley portion. It also kind of lines up with the bottom section of the "gater teeth" on the sides.
It only cuts about 1" off and this is enough to clear the bumper to put it back into the stock looking location.
Re: Things behind front bumper [Re: logansportage] #817790 06/13/07 12:59 AM
Everet Offline OP
I'm going to mount the tube bumper and I'll just rest it against the front of these and then bolt a bracket to where the bumper bolts to the frame, then weld the bracket to tube.
Will probably do this Friday 6/15 or Sat 6/16. My brother-in-law has a welder and plasma cutter.
Will document with pics.
Thanks again,
Re: Things behind front bumper [Re: Everet] #817791 06/13/07 02:43 PM
Hydra747 Offline
Good...Will be glad to see....Keep them blasted Pictures coming!!!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Things behind front bumper [Re: Hydra747] #817792 06/16/07 06:30 AM
Everet Offline OP
Well, took the SawsAll to those bumper things:
[Linked Image] [Linked Image]
Hollow boxes.
Took this SmittyBilt bumper ($50 on craigslist) for a 94 Tahoe and cut the 3/8" frame attachments off
Welded a some homemade brackets and here's where it's at so far. It should finish tomorrow except for something to hide the ugly body work behind the bumper.
Need 2 more brackets and may cut the tubes (maybe just the bottom one) shorter, so they don't get to close to the tire.
Would have been faster but the welder wasn't close to the car so we had to make a couple of trips.
Stay tuned.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Things behind front bumper [Re: Everet] #817793 06/16/07 02:22 PM
Hydra747 Offline
Nice work Everet!
What the heck were those electrical connecters for????
Love the style of the bumper. I'm gonna do the double bar thing also....cool!
Re: Things behind front bumper [Re: Hydra747] #817794 06/17/07 06:49 PM
Cen_Tex_KIA Offline
Been wanting to do that with a tube bumper. Looks good, but I'm thinking maybe one a bit smaler , say Jeep size so the tubes wrap in tighter.
Great work! <img src="/forums/images/graemlins/kewl.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: Things behind front bumper [Re: Cen_Tex_KIA] #817795 06/17/07 07:48 PM
Everet Offline OP
Yeah, I was looking for something smaller but for $50, I'll live with the bigger look.
Everet
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6462 MB (Peak: 0.7695 MB) Data Comp: Off Server Time: 2026-05-29 17:26:16 UTC
