High idling 90 yj w/2.5/5spd #817985 06/11/07 01:12 PM
RidingRoughshod Offline OP
Starts fine, after driving it for a while(10 min), when I engage the clutch the engine rpm's go to 2200. I ve tried tapping the peddle and pulling on it but it stays the same. This happens consistantly, seems to have gotten worse since it's been hot outside.....
Re: High idling 90 yj w/2.5/5spd [Re: RidingRoughshod] #817986 06/12/07 09:56 PM
fresnodb Offline
From past experience I'd start by looking for vaccum leaks and / or a bad coolant temp sensor.
Back in the game!
'94 YJ 2.5 all stock.
Re: High idling 90 yj w/2.5/5spd [Re: fresnodb] #817987 06/13/07 12:07 AM
playinmud Offline
this motors fuel injected right?
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: High idling 90 yj w/2.5/5spd [Re: playinmud] #817988 06/13/07 12:20 AM
BigJim Offline
Well it CAME fuel injected...unless someone did something really stupid it still should be.
Re: High idling 90 yj w/2.5/5spd [Re: BigJim] #817989 06/13/07 01:58 AM
Yeah it's a TBI....Jim, you've always been helpful in the past, any ideas???
Re: High idling 90 yj w/2.5/5spd [Re: BigJim] #817990 06/13/07 02:01 AM
cuervo25 Offline
it may be the iac (idle air control) located on the throttle body. remove the whole throttle body and remove the iac and give it a good thorough cleaning with carb cleaner. especially the iac use a toothbrush if needed. that should help, if not back to the ol drawing board.
Re: High idling 90 yj w/2.5/5spd [Re: cuervo25] #817991 06/13/07 04:27 AM
playinmud Offline
im with cuervo it sounds to me like the IAC, that was the problem with mine and good cleaning fixed it, well it did it every once in a while after that but it hasnt done it in a really long time, but tomarrow i bet its going to now that i brought it up
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6159 MB (Peak: 0.6890 MB) Data Comp: Off Server Time: 2026-06-20 20:25:14 UTC
