22re oil pump #818136 06/12/07 02:45 AM
V
v8yota Offline OP
did anybody ever try to shim the pressure spring in the oil pump to get more oil presure,,,,i bought a new oil off ebay and oil pressure is very low,,,,i want to buy a high vol. pump from EB but he won't have any instock for about 60 days,,,,and i need my truck for work,,,,,,,,,,,,,,what do you guys think about doing this,,,or at least until EB get them in
Re: 22re oil pump [Re: v8yota] #818137 06/12/07 03:36 AM
canuck Offline
Something doesn't sound right. You put in a standard oil pump and pressure is still low. High pressure and high volume are two different things. Is your gauge working properly, is your oil possibly too thin, or worse is your mains worn causing low pressure. Just a few things to consider.
Keep the Shiney Side up. Support our troops.
Re: 22re oil pump [Re: v8yota] #818138 06/12/07 06:14 PM
Z
zoomschwortz Offline
I have been considering doing the same thing to my oil pump and don't know why it wouldn't work. If you look at LC Engineering's oil pressure adjuster, it looks like they drilled and tapped and installed a piece of rod.
You should be able to add a thin washer or two under the spring, but I would use thin ones and add them one at a time until you get the pressure you are looking for.
Why did you change oil pumps?
89 Ext cab 22RE 5 speed
84 Ext cab 22R 5 speed
88 Mitsubishi Macro Cab 2.6 5 speed
Re: 22re oil pump [Re: v8yota] #818139 06/12/07 08:30 PM
engnbldr Offline
>>>*All the spring does is control the bypass, it opens when pressure gets excessive?
The HV pumps have slightly redesigned internals that allow about 4% more volume and this does affect pressure but not a lot. On an engine in good shape, or unless the engine is used for competition or severe service, the HV is not needed.
Typically when we see low oil pressure on these engines, we suspect main bearing clearence. If reading zero, we start looking for a galley plug missing....*EB
*Beats the he** outa me!....*LOL**...
Re: 22re oil pump [Re: engnbldr] #818140 06/13/07 12:10 AM
CJM Offline
dont they only run about 4-6 lbs at Idle anyway ?
cant really remember the exact # , but I do know its very low .
83 Trekker SR5
NEW Trekker forum
Re: 22re oil pump [Re: CJM] #818141 06/13/07 01:37 AM
V
v8yota Offline OP
is this true ,,,,they are that low at idle,,,i would think it should have at least 20 pounds ,,,,well if it is normal then i guess i will let it go until EB gets the hv pumps in
Re: 22re oil pump [Re: v8yota] #818142 06/13/07 01:55 AM
CJM Offline
4.3PSI @ idle ..
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/56oilpress.pdf
. <img src="/forums/images/graemlins/zombie.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: 22re oil pump [Re: CJM] #818143 06/13/07 02:05 AM
V
v8yota Offline OP
WOW,,,, that is hard to believe,,,,how can it be safe with that
Re: 22re oil pump [Re: v8yota] #818144 06/13/07 02:50 AM
engnbldr Offline
>>>*The pump is crank mounted on the front and delivers oil instantly to the shaft and bearings, assuming it is primed.
*One of the neat things about this engine design, this means if any oil at all is available, the critical shaft gets it first.
The fact is, this was an industrial engine originally, designed to run and operate in almost impossible conditions in fork trucks.
The upper end can be a problem, considering the amount of oil we see up there (take off the valve cover and start her up and you will understand) one wouldn't think so, but huge amounts are required due to pressures that are very high.
Still, 4-5 pounds feeds it just fine. If you have 4-5 pounds at 50 MPH, then you can begin to worry.
*Better yet, take my word for it before you take the cover off and start her.....*LOL**...
The 22R/RE has a wonderfully designed and now much copied oiling system, it will run all day at 4-5 pounds and never lack for lube...
Now if this were a chevy...well.. That pump has to suck some up, stuff it in some holes and hope it gets to the shaft after a bunch of twists and turns....the bearings would have no chance at such a low pressure, on the 22RE? No prob.....*EB
Re: 22re oil pump [Re: CJM] #818145 06/13/07 04:05 AM
P
PETE_YK Offline
4.3PSI @ idle ..
Thats MINIMUM. At idle mine il run at 30 cold and about 15 hot (got aftermarket gauge).
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6370 MB (Peak: 0.7419 MB) Data Comp: Off Server Time: 2026-07-16 03:41:07 UTC
