Gas pedal sticking #818422 06/12/07 11:25 PM
F
franko Offline OP
So my gas pedal started sticking the other day and sometimes its scary to drive cause it will stick on the hwy and I'll have to hit it a few times to bring the RPMS down scary as all hell.
Any idea's on why or how to fix, I am going to look at it later this afternoon.
But I thought I would post here to see if you guys have any ideas.
oh ya its a 89 trooper with the 2.6.
Thanks
Franko
1989 trooper 2.6 auto . all stock for now .
Re: Gas pedal sticking [Re: franko] #818423 06/13/07 03:18 AM
JLEMOND Offline
CHANGE THE THROTTLE CABLE ,AND CLEAN THE THROTTLE BODY AND THAT SHOULD DO IT JERRY
Re: Gas pedal sticking [Re: franko] #818424 06/13/07 04:49 AM
Gizzy42 Offline
I've read that there is a pretty common problem with the rubber part on the carb/throttle body end of the cable getting gummy. Removing it, cleaning the cable, and spraying some lube in there took care of it.
If nothing else it could be good for a temp fix till you get a new cable.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Gas pedal sticking [Re: Gizzy42] #818425 06/13/07 01:33 PM
strawmyers Offline
Isuzu Moderator
That's exactly what happened to mine a couple of years ago.
Sean Strawmyer
Re: Gas pedal sticking [Re: strawmyers] #818426 06/13/07 02:41 PM
L
Ldub Offline
There is a device available that clamps to the end of a cable & allows cable lube to be injected throughout the entire length of the cable.
I can't remember the name, but I found mine at a motorcycle dealer a few years ago. They work good, just have a rag at the other end, cause the gunk that gets forced out can cause a bit of a mess.
Larry W - 99 VX s/c
3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
Re: Gas pedal sticking [Re: Ldub] #818427 06/13/07 04:41 PM
F
franko Offline OP
You guys are awesome, thanks so much. I am going to fix it once and for all when I get home from work.
Man this site rocks .. I am new to troopers and you guys are awesome at helping me out..
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6105 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-11-19 23:54:22 UTC
