Gas pedal sticking
#818422
06/12/07 11:25 PM
So my gas pedal started sticking the other day and sometimes its scary to drive cause it will stick on the hwy and I'll have to hit it a few times to bring the RPMS down scary as all hell.
Any idea's on why or how to fix, I am going to look at it later this afternoon.
But I thought I would post here to see if you guys have any ideas.
oh ya its a 89 trooper with the 2.6. Thanks Franko
1989 trooper 2.6 auto . all stock for now .
Re: Gas pedal sticking
[Re: franko]
#818423
06/13/07 03:18 AM
CHANGE THE THROTTLE CABLE ,AND CLEAN THE THROTTLE BODY AND THAT SHOULD DO IT JERRY
[Re: franko]
#818424
06/13/07 04:49 AM
I've read that there is a pretty common problem with the rubber part on the carb/throttle body end of the cable getting gummy. Removing it, cleaning the cable, and spraying some lube in there took care of it.
If nothing else it could be good for a temp fix till you get a new cable.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO on US Wheel 94 series 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
[Re: Gizzy42]
#818425
06/13/07 01:33 PM
Isuzu Moderator
I've read that there is a pretty common problem with the rubber part on the carb/throttle body end of the cable getting gummy. Removing it, cleaning the cable, and spraying some lube in there took care of it. That's exactly what happened to mine a couple of years ago.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
[Re: strawmyers]
#818426
06/13/07 02:41 PM
There is a device available that clamps to the end of a cable & allows cable lube to be injected throughout the entire length of the cable. I can't remember the name, but I found mine at a motorcycle dealer a few years ago. They work good, just have a rag at the other end, cause the gunk that gets forced out can cause a bit of a mess.
Larry W - 99 VX s/c 3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
[Re: Ldub]
#818427
06/13/07 04:41 PM
You guys are awesome, thanks so much. I am going to fix it once and for all when I get home from work.
Man this site rocks .. I am new to troopers and you guys are awesome at helping me out..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6114 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-10 01:48:53 UTCValid HTML 5 and Valid CSS
