Cylinder head application/ exchange #818446 06/13/07 01:29 AM
E
edselsouth1 Offline OP
Hello folks. Glad to be a member of the board. Having just acquired my first Kia, I have a question or two regarding cylinder head application and/or exchange. The vehicle is a 1995 Sportage, 5 speed, 4x4, 2.0 litre, SOHC. After examination, it appears the cylinder head is cracked in the area of the #1 cylinder (pushes coolant out of the radiator when trying to start the truck). Is it possible to swap the cylinder head for a DOHC head, or is that not possible. Assuming that not being a possibility, does anyone on the board have a useable SOHC cylinder head for this truck? Any other cylinder heads interchangeable with the SOHC? Thanks in advance, David.
Re: Cylinder head application/ exchange [Re: edselsouth1] #818447 06/13/07 12:58 PM
A
Airdale73013 Offline
You can not replace the SOHC with the DOHC head many things are different. You may have a bad head gasket causing this problem.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Cylinder head application/ exchange [Re: Airdale73013] #818448 06/13/07 08:41 PM
Axe Man Offline
Kia Moderator Emeritus
I would have to agree with Airdale that it cannot easily be done. I believe some of the castings in the block on the front are different. Also the water pump uses a different timing gear.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Cylinder head application/ exchange [Re: Axe Man] #818449 06/14/07 02:41 AM
E
Airdale, AxeMan, Thanks for the information. It's possible that the problem may be only a head gasket. I have not removed the head as of yet, just trying to line up a head in the event I may need one. Anyone with a useable SOHC , 2.0 head, let me know. Thanks, David
Re: Cylinder head application/ exchange [Re: edselsouth1] #818450 06/14/07 12:22 PM
bombardj1 Offline
http://www.cylinder-heads.com/ have rebuilt heads their heads are complete with cams they should have a sohc head the dohc head is $375 plus $20 shipping sohc should be the same price. good luck check to see if a good headgasket will be the fix but if the head is cracked it will need to replaced I think your head even if cracked can be returned to cylinder-head they are master rebuilders
Re: Cylinder head application/ exchange [Re: bombardj1] #818451 06/16/07 05:04 AM
E
bombardj1, Thanks for that cylinder head info. I'll check with them on the availability if I need a head. Thanks, David
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6099 MB (Peak: 0.6799 MB) Data Comp: Off Server Time: 2026-06-10 01:45:50 UTC
