Prep for Rubicon -- Suggested Spare Parts List? #818737 06/14/07 07:19 PM
BlossomCA Offline OP
In prep for this summer's Carnage Run on 8/17-8/25 (link) I've been researching spare parts for my 4Runner.
I came across the following list from www.rubicon-trail.com but it doesn't specifically include my vehicle.
What parts will likely break?
Pretty much every time I am out on the Rubicon I come across a broken down vehicle - at least one !
Could not help but notice that there are some common weak spots on each vehicle. To make sure my observations were accurate I checked with repair shops around the trail and they supported my notes. So, here is what is most likely to break on your vehicle when you do the Rubicon Trail - and probably on any other rough trail:
CJ, YJ
"the only thing that does not break is the radiator cap"
-- drive line U-joints
-- front axle U-joints
-- locking hubs
-- rear axle shafts (especially with LockRight)
-- steering box
-- steering linkage
-- spring hanger
-- frame cracks
-- motor mounts
Bronco
-- rear axle shafts
FJ40
-- front axle Birfield joints
-- spindle/drum (pre 1975)
-- rear pinion
TJ
-- rear axle shafts (35C)
-- control arm brackets front
[color:"blue"]So what are your suggestions for this vehicle?[/color]
4Runner
-- full size spare(s)
-- front axle shafts
-- tie rods
Thanks for your input...
Joanna
1992 Toyota 4Runner -- 3.0L V6, MT, 4.7 TC
Amateur Radio AE License
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: BlossomCA] #818738 06/25/07 12:36 PM
mrstang01 Offline
I'd post this over on pirate in the trail section, you'll probably get a ton of responses. If you don't do a search first, just don't be surprised if you get flamed, they tend to be a crusty bunch.
Michael
85 4Runner on 36's, Almost there!!!
85 4Runner on 35's, Build also in progress
89 4Runner on 31's, IFS still intact
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: mrstang01] #818739 06/25/07 05:33 PM
Ha! Thanks for your response Michael.
Joanna
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: BlossomCA] #818740 06/27/07 05:37 AM
Stock02 Offline
TTORA.com is also a good place to ask.
02 Tacoma Xcb 4x4, runnin 32"s, 2.5" Daystar spacers, 1.5" Downey HD shackles, AOR sliders, SkidRow Tcase skid, 20# CO2 setup
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: BlossomCA] #818741 07/25/07 09:04 AM
Stock02 Offline
What ya find out so far?
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: Stock02] #818742 07/25/07 08:21 PM
Well I printed lists from multiple sites and books and ended up bringing several extra parts to the Rubicon with me. All turned out well as none of the parts were needed, but at least I was prepared. Although, a Toy owner from another group needed a part that I didn't have -- said he had a pin hole leak in his high pressure hose. Will consider that one for next time.
Joanna
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: BlossomCA] #818743 07/26/07 08:31 AM
Stock02 Offline
I didn't think ya made the run yet. Yer dates were posted for an Aug run. <img src="/forums/images/graemlins/confused.gif" alt="" />
Glad ta hear ya had a good trip.
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: Stock02] #818744 07/26/07 05:48 PM
Still signed up for the August run, but ended up also attending the "pre-run" in the trailrides section. Couldn't say no and glad I didn't.
Looks like there will also be a Rubicon run in September hosted by Marlin Crawler (9/14-9/16) so keep a look out.
Joanna
Re: Prep for Rubicon -- Suggested Spare Parts List? [Re: BlossomCA] #818745 07/27/07 03:42 AM
ldivinag Offline
rule #1: whatever you have broken in the past, will break in the future.
corollary to rule #1: if you have beefed up that part that broke, something else in that link will break...
for example, you broke birfields. so you get longfields. something else will now break, like ring and pinion next.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6323 MB (Peak: 0.7355 MB) Data Comp: Off Server Time: 2026-10-24 03:24:55 UTC
