Page 1 of 3 1 2 3
CAI = More Power = More Gas #819369 06/16/07 08:48 PM
Iron Offline OP
After putting on a CAI a few weeks ago, I've had a chance to run a few tank of gas thru it to see what the milage is!
In short it sucks goats!
While I'd say the good side is you get at least an extra 10 HP, a whole bunch of wheel spinning low end tourqe, the ablity to pass people on the highway with 30' tires on, and 5th gear is now a usable option smile
The down side is it sucks gas!
Before the CAI with the stock air box and 30' tires I was getting 450 to 470KM per 40L fill, (actual numbers were 11.62KM per Litre.)
With the CAI and the same 30' tires I'm now only getting 370 to 390KM per 40L fill, (actuall numbers are 9.44KM per Litre.)
In short im getting roughly 80km less per tank!
When winter comes and I take of the 30' tires and put the smaller 26' ice tires on I'll also be putting the stock air box back! But don't worry, they'll both be back next spring! <img src="/forums/images/graemlins/nana.gif" alt="" />
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: CAI = More Power = More Gas [Re: Iron] #819370 06/16/07 09:02 PM
Hydra747 Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: CAI = More Power = More Gas [Re: Hydra747] #819371 06/16/07 10:09 PM
DEFBOY35 Offline
interesting, my mileage improved slightly.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: CAI = More Power = More Gas [Re: DEFBOY35] #819372 06/17/07 03:46 AM
O
oul053 Offline
maybe ur just driving it alot harder..... <img src="/forums/images/graemlins/lol.gif" alt="" />
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: CAI = More Power = More Gas [Re: oul053] #819373 06/17/07 05:26 AM
DEFBOY35 Offline
i drive the crap out of mine!
Re: CAI = More Power = More Gas [Re: DEFBOY35] #819374 06/17/07 07:11 AM
fokion Offline
How is the setup?????
A cone filter at the engine bay?
My wrong. Just visited your cardomain page and got the answer..
Re: CAI = More Power = More Gas [Re: fokion] #819375 06/18/07 07:40 AM
Lennyburger Offline
If my limited knowledge on this system is somewhat correct, I'm guessing that the colder intake air, whilst improving combustion efficiency, also tricks the airflow sensor into thinking that there is more air flowing than there actually is which might in turn increase the amount of fuel going through the injectors. Maybe that's why the CAI improves power, not because of better air but richer fuel mix??
Does anyone concur? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
KIA, More dirt for ya dollar! 99 Sportage, Pod filter, Bosch Super4 plugs, electric thermo fan, racing pedals, Narva 100W driving lights, Yokhama 235/75R15 Super Diggers....getting to the rest bit by bit.
Re: CAI = More Power = More Gas [Re: Lennyburger] #819376 06/18/07 09:14 AM
A
Adskia Offline
u,d be right mate......air flow meter is sensing that there is more air available and it tells the computer that it needs more fuel to burn the increase in air ......to combat this u can wire in a resistor to the coolant temp sensor and that way u can lean of the fuel mixture when u are cruising dont ask me what size and how u do it cause i have to check and find out..... <img src="/forums/images/graemlins/cheers.gif" alt="" />
THE POWER TO SUPRISE.
Re: CAI = More Power = More Gas [Re: Iron] #819377 06/19/07 06:35 AM
dirtcrazy Offline
With the CAI and the same 30' tires I'm now only getting 370 to 390KM per 40L fill, (actual numbers are 9.44KM per Litre.)
<img src="/forums/images/graemlins/confused.gif" alt="" />
Computes, that does not. I put a cone air filter on mine and I got better performance and mileage. Granted, it is not a cold air intake, since it's getting engine bay air, but still. Odd, that is. yes, odd, that is very!<img src="/forums/images/graemlins/confused.gif" alt="" />
Got torque?
'02 Ford F-350 STD Cab V10 6sp 4x4
12MPG in town and 15-17 on the highway.
Re: CAI = More Power = More Gas [Re: dirtcrazy] #819378 06/19/07 02:11 PM
Iron Offline OP
It gets worse, just filled up last night 38L covered 287KM, thats 7.5km per litre
Nothing has changed, same drive to work, same routines! Now I'm confussed! <img src="/forums/images/graemlins/frown.gif" alt="" />
08' Jeep Wrangler
58' Triumph TR-3A
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6402 MB (Peak: 0.7661 MB) Data Comp: Off Server Time: 2026-10-21 19:13:22 UTC
