Spacer #819621 06/18/07 05:30 AM
Egelwolf Offline OP
Good day all
When doing a ball joint flip, when is the addition of a spacer necessary? I am considering going the conservative route and opt for a 2" suspension lift, and a flip on the front end. Should a spacer be considered and how thick should the spacer be?
Happy travels
'99 Isuzu Frontier (Rodeo) Intercooled 280DT LX
Re: Spacer [Re: Egelwolf] #819622 06/18/07 05:51 AM
lttlbddy Offline
Nothing bigger than 1/4 inch for the spacer.
Re: Spacer [Re: Egelwolf] #819623 06/18/07 11:21 AM
strawmyers Offline
Isuzu Moderator
With 2" of lift, a spacer shouldn't be necessary. When Joe was selling them, he marketed the spacers toward people with 3+" of lift.
Sean Strawmyer
Re: Spacer [Re: strawmyers] #819624 06/21/07 06:23 AM
Egelwolf Offline OP
Any reason why it shouldn't / can't be done with a 2" lift?
Is there a template for the spacer available somewhere?
Re: Spacer [Re: Egelwolf] #819625 06/21/07 11:49 AM
Richard Saylor Offline
What the spacer will gain you in lift is negligible. The spacer is there to help realign the suspension so that it can be brought within specs. With 2 or less inches of lift, this isn't a problem. There is plenty of leeway for the alignment to be brought to specs. But with 3+" of lift, it becomes increasingly more difficult to get it to within specs. That's why you put the spacer in there ; it helps realign things so that it can be properly aligned.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Spacer [Re: Richard Saylor] #819626 06/21/07 11:51 AM
Forgot to add ...
The problem with adding a spacer with such minimal lift is that it can also through your alignment out so bad that it can't be brought within the specs. It's just the opposite of what you'd get with too much lift without the spacer. Hope that made sense.
84 Honda XL185S
Re: Spacer [Re: Richard Saylor] #819627 06/21/07 02:41 PM
Egelwolf Offline OP
Thank you for clearing that up. Much appreciated.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6217 MB (Peak: 0.6965 MB) Data Comp: Off Server Time: 2026-05-29 22:31:24 UTC
