Page 2 of 4 1 2 3 4
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819649 06/21/07 01:17 AM
shifter26 Offline
hmm.. I got 31's and it does pretty decent on slow climbs .. I would go for supercharger idea also ..
Re: SPENDIN SOME MONEY........ [Re: shifter26] #819650 06/24/07 11:03 AM
turtleskia Offline
personally, i brought this idea up last year. the sportage engine can handle up to 8 lbs of boost either way(turbo or supercharged) and it's gonna be a hell of a time fabbing the parts for a supercharger system. i've called and emailed just about every company that builds supercharger kits and no one will touch the 1st gen. sportage.
95 sportage, gone and severly missed.
94 camaro 5-speed v6 with a few addons.
girlfriends 93 s-10 4.3 soon to be lifted and made into a pre-runner
Re: SPENDIN SOME MONEY........ [Re: turtleskia] #819651 06/25/07 12:16 AM
A
Adskia Offline OP
i think its gunna be a case of fabbin up brackets and mounts yourself......i goin the turbo way as it looks easier to do......its an ihi turbo.....brand new rhf5.....for about 350au dollars.....water cooled and roller bearing.....will use an intercooler as well....only want 8pounds boost dont want to go any more than that......
THE POWER TO SUPRISE.
Re: SPENDIN SOME MONEY........ [Re: turtleskia] #819652 06/26/07 02:53 PM
Dave Scott Offline
it's still in my plans, it won't be difficult to fab the brackets and intake, what will be difficult is getting someone to reprogram.
Re: SPENDIN SOME MONEY........ [Re: Dave Scott] #819653 06/27/07 05:29 AM
DEFBOY35 Offline
programing wont be a issue if you go with a stand alone.
that is how i will be doing mine.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: SPENDIN SOME MONEY........ [Re: DEFBOY35] #819654 06/27/07 04:55 PM
A
Adskia Offline OP
im gunna leave the original computer in it as it talks to the immolbizer.....just gunna piggyback a microtech to run the engine.....should work.... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819655 06/27/07 05:50 PM
Dave Scott Offline
hmmmm...... i will have to look into this piggybacking and microtech and stand-alone and, oh, that was it.....
Re: SPENDIN SOME MONEY........ [Re: Dave Scott] #819656 06/27/07 11:04 PM
A
Andrew_Main Offline
You'll have to forgive me as a lot of this goes above my head but the electronics are something I'm familiar with; all the immobiliser does is read the key and send this info to the EMS which then validates it and starts the engine (bit of back and forth but that's about it). I'm assuming you're talking about replacing the EMS for something different? If so just loose the immobiliser and standard EMS and replace with another one which just runs off the ignition switch for starting - of course you loose the security aspects. (No responsibility on this if my mind is failing me - it's been a couple of years since I messed with this stuff <img src="/forums/images/graemlins/smile.gif" alt="" />)
Cheers
Andrew
Re: SPENDIN SOME MONEY........ [Re: Andrew_Main] #819657 06/28/07 08:11 AM
A
Adskia Offline OP
yeah the only thing i want the microtech(very good aftermarket tunable computers)is run the engine......nothing else......so that way if the boys in blue(police)pull me over and want to have a seek peak all they see is a standard computer.....i havent done it but have helped a mate install 1 into a skyline turbo and it worked a treat......
Re: SPENDIN SOME MONEY........ [Re: Adskia] #819658 06/28/07 01:59 PM
Hydra747 Offline
So................................................
What is the first order of bussiness?
What parts are needed and what do we have to have/do?
What Pre-components should we be looking to obtain?
Also where do all of us go from here (besides wait)?
Thanks-Mike
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6440 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-11-02 12:26:47 UTC
