5MG SWAP IN MY 84 RUNNER #819677 06/18/07 07:10 AM
james84runner Offline OP
Can anyone give any help or advise on me puting a 5mg 82 - 88 supra engine in an 84 4runner <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 5MG SWAP IN MY 84 RUNNER [Re: james84runner] #819678 06/18/07 07:47 AM
kewlynx Offline
Hi James, welcome to the board!
This will NOT be a drop-in; this is a PROJECT. Check this gent's 7MG swap:
Ricks Runner Swap
On the last page Rick gave me a couple of links to add as part of his documentation. Do your homework first, and see if you're up to this.
GOOD LUCK! <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 5MG SWAP IN MY 84 RUNNER [Re: kewlynx] #819679 06/18/07 02:01 PM
DirtyHarry Offline
Toyota Moderator
Andy Zook's swap on 4x4Wire is also full of useful information.
http://www.4x4wire.com/toyota/tech/supra/
Re: 5MG SWAP IN MY 84 RUNNER [Re: DirtyHarry] #819680 06/18/07 10:25 PM
Paul Elbisser Offline
Do a search on my name. Alot of info will come up
OK so the direct link didn't work.
Posts older than 1 year under the poster name Paul Elbisser
Also http://www.supracharged.com/
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: 5MG SWAP IN MY 84 RUNNER [Re: james84runner] #819681 06/21/07 03:10 AM
Supra 4x4 Offline
I did this swap over 12 years ago. My truck and info is on Andy Zook's write up. As far as swaps go I think it is easier than most, no adapters needed and 5MGE's are cheap and last forever. The biggest issue I had was wiring but now there are web sites that detail what to do. I used an external VW fuel pump but a EFI tank from a EFI Toyota truck should work. I used a V-6 4Runner radiator (direct bolt in) and electric fans with no issues. Get the 5 spd bell housing from the Supra and any W series truck trans bolts write up with no driveline mods. I ran the 5MGE in my 84 Extra Cab for over 8 years and when I sold it it was still running great. I have a friend who still has a 5MGE in his 85 PU and it runs great. The 7M will have a small power gain but I think the 5MGE is more reliable.
85 4Runner, R151F, Marlins dual case, high steer,and frnt springs. Chevy rears, TJM bumper w/Ramsey winch, custom rear w/swing out tire carrier and rock rails. BudBuilt cross member w/ 2" drivetrain lift, 33" Boggers. 5:71 gears & F&R spool.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6058 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-06-07 11:34:49 UTC
