cooling issue? #819728 06/18/07 04:05 PM
Vman Offline OP
Hey guys, this morning on my way to work,,,,my monty didnt heat up to normal operating temp. I have never had this problem in the last ten years. Any thoughts? Could it be just a failed thermostat? I havnt had a chance to check it out yet. Guess Il know what Il be doing after work.
Thanks for any info <img src="/forums/images/graemlins/cheers.gif" alt="" />
85 2.6l 4cyl
85 2.6l 5-spd
Re: cooling issue? [Re: Vman] #819729 06/18/07 04:43 PM
G
generation_one Offline
theromstat and sender wire is a good place to start
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: cooling issue? [Re: Vman] #819730 06/18/07 04:45 PM
hazy_daze Offline
Sounds like the thermostat may be stuck open. How long has it been since it was replaced? If it's been more than a couple years, get another one (with gasket, of course <img src="/forums/images/graemlins/smile.gif" alt="" />) and slap it in and see what happens. That's the easiest way, and it'll keep the fret-factor down <img src="/forums/images/graemlins/lol.gif" alt="" /> Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Doubt it's going to be the sender wire. It wouldn't move at all if it was. Could be the sender, get the FSM out and check your resistance values across the poles before you replace it though. If they're in spec, it should be the thermostat stuck open <img src="/forums/images/graemlins/kewl.gif" alt="" /> Simple fix!
Re: cooling issue? [Re: hazy_daze] #819731 06/18/07 05:44 PM
Vman Offline OP
Thanks guys,,,I figured it was a failed t-stat. My temp gauge is moving so I figured its good to go. How many times can we say our montys are running cool <img src="/forums/images/graemlins/lol.gif" alt="" />
85 2.6l 5-spd
Re: cooling issue? [Re: Vman] #819732 06/19/07 09:43 AM
StockRaider Offline
my Raider's stat is fluctuating between normal and too warm. I think thats the Stant superstat. lifetime warrenty so thats getting replaced next day off...
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: cooling issue? [Re: StockRaider] #819733 06/19/07 12:42 PM
hazy_daze Offline
If it's warm outside and you're running the A/C, if so equipped, be sure the auxiliary (condenser) fan is coming on. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: cooling issue? [Re: hazy_daze] #819734 06/22/07 12:17 PM
Vman Offline OP
Thanks guys for your help. turns out the sensor wire was barely touching the connector. <img src="/forums/images/graemlins/kewl.gif" alt="" />
85 2.6l 5-spd
Re: cooling issue? [Re: Vman] #819735 06/22/07 01:10 PM
hazy_daze Offline
Well, that was an easy fix <img src="/forums/images/graemlins/kewl.gif" alt="" /> How many times can we say that, as well, about our Monty's <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6234 MB (Peak: 0.7020 MB) Data Comp: Off Server Time: 2026-05-30 00:16:16 UTC
