Page 2 of 4 1 2 3 4
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: justice] #819751 06/19/07 05:16 AM
RDB Offline
There was a thread around Jan this year. I replied to it. My pullies were from Autozone. I think they were around 16.00 each. 48 hr delivery.
92 Montero LS, Rancho Shocks, Hellas, AirLift bags,
99 Superduty 7.3, Rancho 9000s, Superchip, Banks Billet Torque Converter, AirRaid, BFG's, Pillar Guages, 4.5" Exhaust
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: RDB] #819752 06/19/07 06:56 AM
G
generation_one Offline
Goodyear Drive Belt idler Pulley:
Part Number: 49038
plus 5 flat washers sized to fit the bolt and clear the seal on the pulley. $20.
fasteddy
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819753 06/19/07 07:18 AM
G
If the tensioners just need the bearings, see if grainger or an industrial supply can get them. The pulleys are usually ok, it's the bearings that give out on em. Give that a try, may save ya some moolah <img src="/forums/images/graemlins/kewl.gif" alt="" />
what ? have they seized, or making noise or what ? perventative maintenance ?
it is my alternator bearing (I guess) that are screaming ....and big mean dogs hear it and start to chase me.
Has anyone changed those bearings? I looked at the manual, and it appeared do-able. I am afraid I will get it apart and need a special tool to get it back together
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: generation_one] #819754 06/19/07 07:29 AM
I just replaced my tensioner pulley but it was my Alt making all the noise. Stony, I can overnight you my old pulley which is actually good if you want it. Let me know. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: generation_one] #819755 06/19/07 12:46 PM
hazy_daze Offline
I'll cross this number to a NAPA # when I get to work, and order one from ATL if I don't have one in stock. I'll also check to see if there is one that is a more direct replacement (ie no washers) I'll post up the info later today.
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819756 06/19/07 01:07 PM
Dan1171 Offline
There should be some numbers on the bearings that can be cross refenced at some place like Applied Industrial, Motion Industries, Grainger, even McMasterCarr.
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: Dan1171] #819757 06/19/07 03:51 PM
Boertjie Offline
AFAIK Volkswagen 4-cyl tensioner pulleys are identical.
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: Boertjie] #819758 06/19/07 04:21 PM
hazy_daze Offline
I crossed the Goodyear # to a NAPA TEM 38042. With the five M10 washers behind it, it does work. I just put it on mine and ran it for a bit. The only concern is the lack of inner lip. Doesn't appear to be necessary, though. The grooves are located and tracked by the crank, fan and alternator <img src="/forums/images/graemlins/kewl.gif" alt="" />
If there's any way this thread can be archived for future reference, that'd be great. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: hazy_daze] #819759 06/19/07 07:10 PM
RDB Offline
The contact surface of the pully for the belt is slightly convex and is enough to keep the belt centered. Sure beats the dealer charges doesn't it!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Kinda Urgent: Need tensioner pulleys for my V6 [Re: RDB] #819760 06/19/07 07:16 PM
hazy_daze Offline
At $12.76 apiece, ummm... yeah <img src="/forums/images/graemlins/lol.gif" alt="" />
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6424 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-07-17 01:04:22 UTC
