From the Looks of the Spark Plugs...
#819801
06/18/07 07:59 PM
My 1996 Sportage is running rough. Intermittent error code for a miss on cylinder #3. Changed plugs, wires, coils. It was due anyway.
Still runs the same, same error. Pulled the plugs. #1 is pretty much white, a little spot of brown on the tip. #2 looks evenly tan, #3 and #4 are tan except for one third of the tip on the side is white.
I'm thinking I've got a fuel injector problem here. My Kia overheated and I'm thinking this might have affected the injectors or the injector wiring. How do I check the injectors for proper operation if this is indeed what it might be?
Thanks, Stanley
Re: From the Looks of the Spark Plugs...
[Re: sjs]
#819802
06/19/07 04:37 AM
Kia Moderator Emeritus
If you overheated the engine I'd check the engine compression first. You might have fubar'ed a valve or have a blown head gasket.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#819803
06/23/07 08:40 PM
Thanks, Axe Man.
Went out and bought a compression tester. Maybe its me, but I get #1-120, #2-60, #3-90, #4-90. From researching the forum I see I should have 164 in each cylinder. I am surprised that the Sportage ran at all. I did notice reduced power and gas mileage, though.
Is there any posts on the forum for the procedure to change the head gasket?
Stanley
[Re: sjs]
#819804
06/24/07 11:47 PM
If you are confident that you used the compression gauge properly then yes, you roasted something.
Before tearing the engine down check first that the timing belt hasn't jumped a cog. If it did it will greatly affect the compression results. If the belt is OK you have no choice but to pull the head and see what's up.
I can provide engine teardown instructions if you need them.
[Re: Axe Man]
#819805
06/25/07 08:27 AM
before pulling the head off if ur not too sure bout the compression y dont u take it to a mechanic just to get it doubled checked no point taking on a job like that if u dont need to. <img src="/forums/images/graemlins/kewl.gif" alt="" />
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
[Re: sjs]
#819806
06/25/07 09:18 AM
before you pull the head off......tip a small amount of oil down each plug hole......only about 50-100mls and do the compression test again .....if the compression test readings are higher......then u have a ring sealing problem......time for a new motor....... <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
THE POWER TO SUPRISE.
[Re: sjs]
#819807
07/02/07 07:52 PM
...I get #1-120, #2-60, #3-90, #4-90....I should have 164 in each cylinder.
DId you test with the throttle wide open? TO reach 164..which by the way would be over 12 compression ratio (???) it would need a full gulp of air and anyway, at low rpm, theoretical ratio will probably never be reached.... 120 is 9.16 compression ratio....
