Where are some good trails in North Carolina? #820110 06/20/07 03:51 AM
Y
Yotadude Offline OP
I'm always looking for a good trail to take my cj-7 and my Toyota Tacoma but it seems like all I ever come up with is construcion sites and trespassing. I need some better ideas.
Re: Where are some good trails in North Carolina? [Re: Yotadude] #820111 06/20/07 04:02 AM
playinmud Offline
ive found that when your in a parking lot and you see another jeeper or trucker pull in you be friendly and ask them questions like that, seems to work
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: Where are some good trails in North Carolina? [Re: Yotadude] #820112 06/20/07 07:31 AM
BobRowe Offline
Call, e-mail, or write to United Four Wheel Drive Associaations (UFWDA). They will tell you the name and contact info for the regional association in North Caroline. Then contact the regional association. They will tell you where the trails are, and will also likely give you the contact info for the off-road clubs in NC.
Re: Where are some good trails in North Carolina? [Re: BobRowe] #820113 06/20/07 10:19 AM
DRaider90 Offline
I am not sure what part of North Carolina you are in but the 2 big hot spots in NC are (and one outside of NC):
Uwharrie National Forest/Badin Lake Recreation Area
-Best suited for Mild to Moderate Wheeling, with some pretty challenging areas. A rig with 33"+ and lockers should be able to tackle all trails (including Daniel). But there is fun to be had for even stock rigs.
Upper Tellico OHV Area/Murphy NC
-There are only a few trails for slightly modified vehicles. It is recommended to at LEAST have 31" tires, 33" Preferred. If your going on anything like Helicopter Pad, Guard Rail etc at least 35/37"s and up. Lockers are also a big help here.
Callalantee OHV/Mountian City TN
-Located right outside of NC Callalantee is a popular OHV area, and not just for ATV's (the link). There are tons of trails with varying difficulties. There are trail maps available there, but they can be sketchy and misleading. So having a GPS unit or a friend with that knows the trails is a good idea.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Where are some good trails in North Carolina? [Re: Yotadude] #820114 06/20/07 01:31 PM
DBL_DTY97TJ Offline
For the eastern part of the state there's always a nice easy ride down Carolina beach...but that's not 'bout wheelin, it's about going to the beach. Or try NCKrawlers.com - think they're in Jacksonville (Maybe Greenville). There are some others - hit google. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6059 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-06-17 04:19:35 UTC
