Hi Amp Alternators.....?
#820202
06/20/07 05:46 AM
Anyone know where I can get a high amp Alternator for my 3.4L (with a serpentine belt)? I'd like something that is atleast 130 amps.....160 amp would be best though. And, I'd really, really like a bolt in application (prolly too much to hope for though). Anyone know where to look for something like this?
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: Hi Amp Alternators.....?
[Re: CORunner93]
#820203
06/20/07 05:53 AM
Depending on where in CO you are, there are a few local shops that will gut and rebuild a stock alternator and get a decent amount of increase. The only problem with that is a very limited warranty.
I'm in Colorado Springs, and if is close enough and you give me a little time I can probably remember where the stereo shop I work at used to send them to get beefed up.
[Re: Mikeweb]
#820204
06/20/07 06:17 AM
Iv'e thought about going that route...having the original rewound. But, I've read some bad things about that...usually of them not lasting very long.....I'm all about the reliability.
I've found a few places that sell a bolt in application for about $500....which is a bit (actually a lot) more than I was hoping to spend.
I've been reading a lot about small case Chevy altenators that put out 110..and even up to 160 amps. Anyone know anything about those?
[Re: CORunner93]
#820205
06/20/07 06:18 AM
I installed a 160 amp powermaster on my 3.0, ErikB installed one on his 22r. We got them at Summit. Here is a write up on my install and in the write up is a link for the 22r install. http://www.pirate4x4.com/forum/showthread.php?t=458156&highlight=OOP%27S
"Serenity through Sobriety"
