1 piece driveshaft #820332 06/21/07 12:23 AM
N
norcalsvx Offline OP
got my one piece driveshaft in and install, it's working great and with 1/2 the weight it seems to rev out a little quicker-
1994 toy 22re
Engbldr. street rv head 261c,LC header,Downey dualshocks, BJ spacers, OME torsions, 33x10.50 BFG muds budbuilt xmember/skid plate 4.88's locker custom exhaust
2006 Subaru Forester XT
1994 Subaru SVX
1979 Mazda rx7
Re: 1 piece driveshaft [Re: norcalsvx] #820333 06/21/07 12:24 AM
N
$300 for it if anyone else needs one steve @ SB driveline 408-995-6000
1994 toy 22re
1994 Subaru SVX
1979 Mazda rx7
Re: 1 piece driveshaft [Re: norcalsvx] #820334 06/21/07 03:35 AM
OOP'S Offline
I hope that is installed. Why didn't you just go to Sacramento Driveline?
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 1 piece driveshaft [Re: OOP'S] #820335 06/21/07 05:08 AM
kewlynx Offline
Shoot, up here they want $250 to balance a driveline, and that's with you doing the R&R. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
**ubi apis- ibi salus**
Re: 1 piece driveshaft [Re: OOP'S] #820336 06/21/07 04:12 PM
N
i put it in myself (i work at a shop) i wnet with steve because he is proven himself with his work-
1994 toy 22re
1994 Subaru SVX
1979 Mazda rx7
Re: 1 piece driveshaft [Re: norcalsvx] #820337 06/22/07 02:58 AM
ChrisH Offline
i agree. SB driveline is awesome. I'm having a little bit of vibe issues, myself. But i'm not sure if it's the DS, my rear diff (it's singing a song nowadays <img src="/forums/images/graemlins/scared.gif" alt="" /> ) or my pinion angles.
anyway.. good choice <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Steve knows his stuff!
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: 1 piece driveshaft [Re: norcalsvx] #820338 06/22/07 06:31 PM
OOP'S Offline
Cool, stick with what you know. I have had good luck with Driveline Service of Sacramento and AA Driveline in Rancho Cordova.
David Fritzsche
Roseville, CA
Re: 1 piece driveshaft [Re: norcalsvx] #820339 06/23/07 06:00 AM
Snowtoy Offline
Did you drop the pinion down yet?, it should take either a 2-3* shim. 2-3* doesn't seem like much of a difference, but it is enough to cause premature wear/failure of the u-joints.
Re: 1 piece driveshaft [Re: Snowtoy] #820340 06/23/07 07:21 PM
N
hmm no i just installed it in w/o shims
1994 toy 22re
1994 Subaru SVX
1979 Mazda rx7
Re: 1 piece driveshaft [Re: norcalsvx] #820341 06/23/07 09:17 PM
Snowtoy Offline
The 1pc d-line sits at a different angle than the original, so you have to rotate the pinion down to match the angle of the tranny flange. The shim goes between the spring and the perch, and run abot $12(when I purchased mine). Contact 4x4 labs here in GV, they may have the shims, if not Foothill 4x4 in Auburn should, I don't think Trucksmart will have them. Measure the amount you need, I used a 3* on my '90 x-cab, it has a 3" lift, so a stock rig may need less of a shim.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.010s) Memory: 0.6409 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-11-02 03:00:43 UTC
