5spd transmission hard to get into 1st gear and reverse #820439 06/21/07 04:33 AM
Y
Yotadude Offline OP
I haven't had my 00 Tacoma but a few months and I've started noticeing that sometimes it don't want to shift into reverse or first gear without shoving it in. Is this normal for a Tacoma with 114k miles on it? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 5spd transmission hard to get into 1st gear and reverse [Re: Yotadude] #820440 06/21/07 12:48 PM
88toy4x4 Offline
Somewhat normal. Tacoma manual transmissions are great but they can be a little notchy. Do you know if the gear oil in the transmission has been changed before? Most 5spd owners don't think to check/change the trans oil when they are supposed to. I would suggest checking the oil to see if it is dirty and if so, drain and refill with new. Most people use just standard gear oil(80w-90w). A good many have reported that they get better shifting using Redline MT-90. It is a synthetic gear oil that is not "too slick" for the syncros in the tranny. It however is more expensive than the regular gear oil plus you have to find a place that carries it like a speed shop. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 5spd transmission hard to get into 1st gear and reverse [Re: 88toy4x4] #820441 06/21/07 02:15 PM
Y
Yotadude Offline OP
Thanks man that makes me feel better about it. I'll try changing the gear oil in the transmission. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 5spd transmission hard to get into 1st gear and reverse [Re: Yotadude] #820442 07/19/07 09:24 AM
danno Offline
Mine gets hung up once in a while too. I usually just let the clutch out a bit and spin the gears so they line up.
Re: 5spd transmission hard to get into 1st gear and reverse [Re: Yotadude] #820443 07/20/07 02:47 AM
kewlynx Offline
Always get a 'new to you' truck on YOUR maintenance schedule, starting with changing all fluids. <img src="/forums/images/graemlins/kewl.gif" alt="" />
If you still have problems, the shifter bushing might be worn; 1-banana job.
www.redlineoil.com <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6065 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-17 03:33:15 UTC
