LSPV Rebolting Idea-Any reason why I shouldn't do this? #820641 06/22/07 05:55 AM
Multimetal Offline OP
I'm halfway through putting a 3 1/2" lift on my truck (3" springs, 1" over stock shackles) and I'm to the point of dealing with the LSPV. I was thinking of doing the arm/turnbuckle trick, but as I was under there today I noticed that the top mounting bolts on the LSPV are about 3" from the bottom bolts-could I just reposition the LSPV by bolting the top mounting holes into the bottom frame holes? Seems like this would avoid having to fab or buy a new bracket. Would there be any danger in having 2 bolts holding it in instead of 4? I can't think that it would be under much stress.
85 Pickup, Desert tan spray job, 3" Rough Country lift, Marlin shackles+bumper, Chebby igniter, 33x10.5" BFG's
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: Multimetal] #820642 06/22/07 07:38 AM
cam01 Offline
I think it sees a fair bit of stress. Mine was actually limiting droop on my rear axle before I cut it off and zip tied it up.
88 V6 4Runner, 3.4 swap, SAS, front E locker, rear EZ locker, dual cases 2.28/4.7, 63" Chev rears, rears up front etc.
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: cam01] #820643 06/22/07 03:25 PM
Red_Chili Offline
Toyota Section Staffer
I found Front Range Off Road Fabrication's manual proportioning valve (same as Summit's, but with metric adapters) to be lightyears more effective than the LSPV. Solves several problems!
And yeah, Toyota put 4 bolts on there for real reasons.
-Bill
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: Red_Chili] #820644 06/22/07 03:50 PM
Scerb Offline
I second getting the summit proportioning valve. Huge improvement over stock!
-Scerb
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: Multimetal] #820645 06/22/07 06:28 PM
OOP'S Offline
How hard is it to fab an extension, it is a flat piece of stock with a few holes drilled in it.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: OOP'S] #820646 06/23/07 12:37 AM
Vanishing_Point Offline
Try welding threaded rod onto the axle mounting side.
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this? [Re: Vanishing_Point] #820647 06/23/07 01:25 AM
Thanks for the advice guys, guess I'll fab up a plate or try zip-tying it off. I want to replace it entirely, but it might be a while till I get a new valve!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6140 MB (Peak: 0.6922 MB) Data Comp: Off Server Time: 2026-11-16 08:38:12 UTC
