Rear Main Seal #820743 06/23/07 04:12 AM
RLBomber Offline OP
I really hope this isn't the problem, but is there any easy way to tell if the rear main seal is going bad. I seem to be dripping oil around the clutch housing and the rear of the engine. It sure would be nice if it's only the oil pan gasket but I doubt it.
By the way, it's a 89 YJ, 4.2.
Re: Rear Main Seal [Re: RLBomber] #820744 06/23/07 04:43 AM
O
oldgreen Offline
run your finger around the back of the valve cover, maybe you will be lucky and its just a bad valve cover gasket.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: Rear Main Seal [Re: RLBomber] #820745 06/23/07 06:07 AM
BigJim Offline
Install a NEW pcv and check for good vac on the valve cover hoses. blowby pressure in the engine can cause the rear main to leak if it cannot escape thru the vent system.
Re: Rear Main Seal [Re: BigJim] #820746 06/23/07 06:29 PM
Brown81CJ5 Offline
For your sake I hope that it is not the rear main too!
Some will tell you that it can be changed with the motor in the Jeep, which I'm sure it can. But it is much easier with the motor outta the Jeep.
I had to change the rear main seal on my Jeep recently, and driving the old seal out is kinda a PITA.
Good luck, and let us know what you find out.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Rear Main Seal [Re: Brown81CJ5] #820747 06/24/07 01:20 AM
RLBomber Offline OP
I don't really believe it and will give it a couple more days, but I changed the PCV and the rear breather element on the valve cover and drove the jeep all day. Never once did I find an oil leak under the jeep.
Keeping my fingers crossed!!
By the way, you guys and this forum is the best.
Re: Rear Main Seal [Re: RLBomber] #820748 06/24/07 01:42 AM
BigJim Offline
I have had em with so much blowby that I had to take the pcv OUT and hook both the hose to the breather and the pcv hose to positive vacuum! It has always stopped the rear main leak too.
Thanks for the reply get back here in a few days and give us a update.
Re: Rear Main Seal [Re: BigJim] #820749 07/02/07 12:14 AM
RLBomber Offline OP
After a whole week and no oil drippings, I am a very happy camper right about now.
Thanks Big Jim!
Re: Rear Main Seal [Re: RLBomber] #820750 07/02/07 12:28 AM
BigJim Offline
Thanks man...I really needed that! It has rained here for at least 10 days and all day today!
Glad to have helped.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6196 MB (Peak: 0.7021 MB) Data Comp: Off Server Time: 2026-06-10 01:33:14 UTC
