91 - 22re not tdc? #820833 06/24/07 03:12 AM
W
wasatchmtnbike Offline OP
I just finished putting a head gasket in my daughters 91 2wd w/ 22re. I put it all back together and when we tried to start it up it kind of backfired through the intake manifold! Never did start.
Could this mean that it's not TDC? Could I be 360 degrees off? I'm not totally sure I had it at TDC, I had the timing mark on 0 and the number 1 piston was at the it's highest mark but I don't know if it was really at TDC. Did I screw anything up?
Dang! It's her first vehicle and I was so excited to get it running for her. I bought it last summer for $300 and have been working on it when I had time.
Any help or advice would be apprediated.
Thanks,
Gary
91 - Toy 2wd - my daughter's
02 - Toy 4X4 dbl cab - mine (sometimes vice-versa!)
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820834 06/24/07 03:23 AM
Adam F Offline
Yea, you probably are at 180 degrees out. You probably had the piston set at tdc but on the power stroke, not the compression stroke.
Only damage you could have done would be to the intake manifold. I've seen them crack due to the backfire, or blow the gasket out.
Easiest way to find TDC is to put your thumb over the number one spark plug hole, rotate the crank until you feel compression. Then CAREFULLY stick a screwdriver in the cylinder, and feel for the piston to come up as far as it will and then start to go back down, rotate it back so its all the way up, and then line up your 0 degree timing mark on your crank pulley.
97 4R, stock, daily driver
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820835 06/24/07 03:25 AM
V
v8yota Offline
did you have it at TDC on the compression stroke,,,the dis. might be 180 out
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820836 06/24/07 03:42 AM
W
Thanks for the replies! That was fast.
I'll try reinserting the distributor 180 opposite and see what that does. I'll let you know.
Gary
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820837 06/24/07 04:43 AM
cktoy Offline
mine did that when I did the timing chain .I had my dist 180* out I believe.took it out ,put it back in at correct position and viola off I go
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820838 06/24/07 04:57 AM
engnbldr Offline
Thanks,
Gary
>>>*Hopefully it is just off time.
*But it is pretty easy to bolt the head down with the cam out of time to the short block, this can draw a valve open into a piston.
If the valve gets bent enough, the symptom is backfiring through the intake and...no start...*EB
*Beats the he** outa me!....*LOL**...
Re: 91 - 22re not tdc? [Re: engnbldr] #820839 06/25/07 09:16 PM
W
Update: I changed the distributor 180 and it seems to want to start and it kind of does when I spray starting fluid into the intake but it backfired once again from the intake. The starting fluid makes it run a little bit and then dies.
Not sure what to try next. <img src="/forums/images/graemlins/confused.gif" alt="" /> What's the best way to see if it's getting fuel? Should I try loosening the fuel line into the injector manifold?
I hope I don't have a bent valve!
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820840 06/25/07 09:22 PM
Adam F Offline
loosen the line coming into the fuel filter
Re: 91 - 22re not tdc? [Re: wasatchmtnbike] #820841 06/25/07 09:27 PM
4Crawler Offline
You can also try the fuel pump test jumper and listed for the fuel pump:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: 91 - 22re not tdc? [Re: 4Crawler] #820842 06/26/07 03:42 AM
canuck Offline
Don't use starter fluid. You run the chance of blowing everything to pieces plus it dries the cyl wall of oil. Get a squeeze bottle filled with gas. Use this to prime the engine. <img src="/forums/images/graemlins/shame.gif" alt="" />
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6430 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-23 21:20:11 UTC
