4M40T on ebay #820918 06/24/07 04:04 PM
toddstidham1 Offline OP
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: 4M40T on ebay [Re: toddstidham1] #820919 06/25/07 04:39 PM
hazy_daze Offline
What would be involved in doing a swap from V6 LWB LHD to something like this? I know you would want the computer, but what else? Anybody done a swap similar to this?
Re: 4M40T on ebay [Re: toddstidham1] #820920 06/25/07 09:15 PM
Pajerist Offline
if you'll try hard, for this money you can get the whole truck from Japan!
Cheers,
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: 4M40T on ebay [Re: hazy_daze] #820921 06/25/07 10:32 PM
L
Lee N Offline
Search for posts by Boertjie. He swapped one of these in a Gen I. Had a pretty good write-up on it IIRC.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 4M40T on ebay [Re: Pajerist] #820922 06/25/07 11:33 PM
hazy_daze Offline
Cheers,
Really? Do you have any site suggestions or contacts?
Good info <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thx, will do. Can anybody answer as to what it takes to import one of these JDM Pajero's into the US? I've been reading a bunch of stuff on it and it seems very convoluted <img src="/forums/images/graemlins/lol.gif" alt="" /> to say the least. You Canucks seem to have it down pat <img src="/forums/images/graemlins/smile.gif" alt="" /> Do ya'll know if any US guys have imported one successfully? Or is it easier to import one from Japan to Canada then to the States?
Re: 4M40T on ebay [Re: hazy_daze] #820923 06/26/07 12:51 AM
jfarsang Offline
Unfortunately, you can't.
The US has a 25 year import rule whereas Canada has it set at 15 years at the moment. I say at the moment because politicians are pushing legislation to change it to 25 years just like you guys in the US. They did this in Australia not too long ago when the JDM market started to boom.
1/2 cuts and engines you can import no problem.
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: 4M40T on ebay [Re: jfarsang] #820924 06/26/07 07:20 AM
Boertjie Offline
I looked at the item as advertised.
The transplant should be reasonably simple, since the drive-train is complete. Engine/tranny mountings would be the only major fabrication.
Budget to have prop shafts modded to suite.
Radiator on your vehicle is adequate.
If you are going to fit the inter-cooler, you will have to install a scoop in the bonnet.
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: 4M40T on ebay [Re: Boertjie] #820925 06/26/07 02:13 PM
hazy_daze Offline
Would a hood scoop from a JDM Pajero with the intercooler have a scoop that would work?
Re: 4M40T on ebay [Re: hazy_daze] #820926 06/26/07 02:19 PM
PHIL_ Offline
Would have to be 93+ with 2.8, since early genII 2.5 hoods were double-walled, with the intercooler air duct is at the top of the grille.
Re: 4M40T on ebay [Re: PHIL_] #820927 06/27/07 07:28 AM
Bernoulli Offline
Everyone may already know this but the MMC parts guy (Capalaba, QLD OZ) told me that the 4M40 conversion is relatively simple, but one should try and get a trans at the same time because the newer trans is stronger. He says the 4M40s are stronger and more reliable than the 4D56s (chain drive instead of timing belt).
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6399 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-07-17 05:22:15 UTC
