A/C compressor grind under 1000 rpms #820930 06/24/07 04:12 PM
Smorticvs Offline OP
1990 Trooper w/ 2.8 v6. When a/c is on, and idle is under 1000 rpms, the compressor spins and sounds just like ICE IN A BLENDER. When rpms go over about 1000, clutch engages and noise goes away. A/C blows cold. I know that the previous owner changed the compressor, and it is prob. converted to r134. If I can get away with just changing the compressor's clutch, I'd be saving money and time. If anyone out there has experienced the same phenomenon, please let me know. Thanks!
Re: A/C compressor grind under 1000 rpms [Re: Smorticvs] #820931 06/24/07 10:43 PM
CPOM Offline
I think the best way to find out if it is the A/C clutch is to take a look at it when it is cycling to see if it makes noise when disengaged.
CHRIS
98 Amigo, 92 Pup
Re: A/C compressor grind under 1000 rpms [Re: Smorticvs] #820932 06/25/07 01:46 AM
JLEMOND Offline
SOUNDS LIKE THE BEARING IN THE CLUTCH IS GONE, NOT A BIT UNUSUALL , JERRY
Re: A/C compressor grind under 1000 rpms [Re: JLEMOND] #820933 06/25/07 02:40 PM
Thanks, guys. I have a feeling that it is the clutch bearing. Now, if anyone can tell me what tool(s) I need to get at that bearing...
Re: A/C compressor grind under 1000 rpms [Re: Smorticvs] #820934 06/26/07 01:18 AM
JLEMOND Offline
YOU CAN DO THIS ON THE VEH, IF YOU HAVE ENOUGH PATIENCE, REMOVE THE CENTER BOLT A MM WRENCH, WILL DO AND THEN REMOVE THE FRT CLUTCH PLATE , YOU WILL NEED A SPECIAL PULLER FOR THIS ,DO NOT USE 2 SCREWDRIVERS ,YOU WIL BEND THE CLUTCH PLATE, THEN REMOVE ONE LARGE SNAP RING INSIDE THE FLYWHEEL, THEN REMOVE THE FLYWHEEL (THE PART WITH THE BELT GROOVES), THIS IS THE PART THAT HAS THE BEARING IN IT , REPLACE THE BEARING AND TAP IT BACK ON TO THE COMP SNOUT , REINSTALL THE SNAP RING, AND THEN REPLACE THE FRT CLUTCH PLATE OH DON,T LOOSE THE SMALL THIN WASHERS THAT ARE IN THE FRT CLUTCH PLATE ,THEY ARE THE SPACERS TO GET THE CLUTCH PLATE CLEARENCE CORRECT, TIGHTEN THE 10 MM HEAD BOLT BACK TO ABOUT A MAX OF 9 FT LBS OR YOU WILL BREAK IT . JERRY
Re: A/C compressor grind under 1000 rpms [Re: JLEMOND] #820935 06/26/07 02:28 PM
Thanks, Jerry. Your expertise is sooo much appreciated. While on the subject of A/C systems... I was wondering if shops convert the old r12 systems to r134 as a matter of course whenever a/c components are replaced.
Re: A/C compressor grind under 1000 rpms [Re: Smorticvs] #820936 06/26/07 02:37 PM
JLEMOND Offline
SOME SHOPS DO CONVERT ,ON YOUR TRUCK IT WOULD BE REALTIVELY EASY AS GM MAKES THE R4 COMPRESSOR AND IS R134 COMPATIBLE CONFIGURATION , IT LOOKS IDENTICAL TO THE R12 COMP. , R12 IS PRETTY EXP TO RECHARGE A SYSTEM WITH , IF EVERYTHING ELSE IS WORKING OK, I WOULD LEAVE IT R 12 IT WORKS MUCH BETTER THAN 134 SYSTEMS, JERRY
Re: A/C compressor grind under 1000 rpms [Re: JLEMOND] #820937 06/29/07 03:44 AM
NATO308 Offline
Freeze 12 will make your 134 system cool like R-12. If it were only legal to add Freeze 12 to a 134 system without a lot of work....
Freeze 12 is ≈75% Freon 134A and ≈25% Freon 142B.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6196 MB (Peak: 0.6979 MB) Data Comp: Off Server Time: 2026-07-13 10:34:14 UTC
