4L not engaging after lift #820985 06/24/07 10:04 PM
clseidler Offline OP
Quick question for anyone willing to help: I just had a 4" suspension lift along with new 33x12.5 tires installed on my 2005 Wrangler Sport. Everything seemed fine until I went out on a little backroad trip and discovered that I cannot engage 4 wheel low. Well, here is what happens specifically: It will shift into low, but when I try to put the car in gear, it suddenly drops out of 4L, presumably into neutral. My question is whether the lift might have something to do with this or whether it is just a coincidence and my transfer case is damaged. I perused the FAQ section, but didn't see anything that addressed this question specifically. Any help would be greatly appreciated. Thanks
Re: 4L not engaging after lift [Re: clseidler] #820986 06/24/07 10:33 PM
TX4wl Offline
check your linkage.....this happens when lifting...your linkage get outta wack <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4L not engaging after lift [Re: TX4wl] #820987 06/25/07 04:40 AM
playinmud Offline
i know they make this adapter that takes the place of your old shifter linkage, i cant recall the name of it and i looked in the 4wd magazine and didnt see it, maybe someone else on here will know the name of it
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: 4L not engaging after lift [Re: clseidler] #820988 06/25/07 06:04 AM
fred1980 Offline
Did you install a transfer case drop along with your lift kit? If so that is your problem, the t-case drop threw your linkage out of whack and you need to adjust it. Very easy 5-10 min job.
Hope this helps,
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: 4L not engaging after lift [Re: fred1980] #820989 06/25/07 11:54 PM
I had the lift installed in a shop. I would assume they did install a transfer case drop, but you know what they say about assuming. I'll check with them. Thanks for your help guys.
Re: 4L not engaging after lift [Re: TX4wl] #820990 06/26/07 04:01 AM
Tourglide Offline
There is a bracket you can buy to correct that problem. You can find it at Quadratec.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6101 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-06-21 00:15:44 UTC
