'05 Wrangler blower resistor location #821231 06/26/07 03:58 AM
Tourglide Offline OP
My blower only works on high which indicates a failed blower resistor block. I purchased a new one and thought it would be a simple install. I can't find it and I have looked everywhere under the right side of the dash. Does anyone know where it is hidden.
Re: '05 Wrangler blower resistor location [Re: Tourglide] #821232 06/26/07 04:10 AM
playinmud Offline
might also be your fan control switch, heard of those going out also, but the resistor is located under the passenger dash in the black box... about a 5 minute install... you will need a 8mm nut driver or socket to remove the cover plate and the resistor
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: '05 Wrangler blower resistor location [Re: playinmud] #821233 06/26/07 04:30 AM
That's the problem. I can't seem to find the cover plate. Could it be different on an Unlimited? Can anyone post a picture or a link with pictures? I know I probably sound like an idiot but I really could not find it even after removing several parts and the right speaker assembly.
Re: '05 Wrangler blower resistor location [Re: Tourglide] #821234 06/26/07 04:48 AM
playinmud Offline
its a diamond shaped piece of plastic held on by two screws there is a 4 wire connector visible as well
Re: '05 Wrangler blower resistor location [Re: playinmud] #821235 06/26/07 04:59 AM
I can't ask for more than that. I'll check it out tomorrow and let you know how I made out. I don't feel like looking now since it's raining and I don't have a garage.
Re: '05 Wrangler blower resistor location [Re: Tourglide] #821236 06/27/07 01:22 AM
I found the location and decided it was in a lousy spot to make replacement easy. I took it to a nearby jeep dealer and had a tech install it on his lunch break for twenty bucks. It was money well spent because it took him a whole half hour to replace it.
Re: '05 Wrangler blower resistor location [Re: Tourglide] #821237 06/27/07 03:27 AM
playinmud Offline
wow my buddy did his in like 5 mins
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6137 MB (Peak: 0.6906 MB) Data Comp: Off Server Time: 2026-06-07 04:39:56 UTC
