22re stalling under throttle #821288 06/26/07 05:18 PM
eightyeight Offline OP
not my truck, but a friend of mine's '93 22re pickup.
runs ok at idle. snap the throttle and it stalls. can bring up the RPMs slowly, but it begins to break up at higher revs.
no CEL. no codes.
any ideas? still need to get a timing light and fuel pressure gauge on it, but timing WAS ok. and fuel filter is not plugged.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 22re stalling under throttle [Re: eightyeight] #821289 06/26/07 05:55 PM
Staceman Offline
Vacuum leak? Especially around the rubber connectors for the air tube.
Re: 22re stalling under throttle [Re: Staceman] #821290 06/26/07 05:59 PM
possible. i guess that was checked already, but i will look again.
-matt
Re: 22re stalling under throttle [Re: eightyeight] #821291 06/27/07 02:31 AM
kewlynx Offline
Make sure the TPS is set up properly; root of all evil.
Might also have a plugged EGR.
**ubi apis- ibi salus**
Re: 22re stalling under throttle [Re: kewlynx] #821292 06/27/07 02:37 AM
yotaman7 Offline
Yes, if you don't find any vacume leaks I would check the egr system. The symptoms sound like that of an egr problem.
Someone gave me a 92 saturn sl2 not to long ago because if you tried to accelerate it would cut out and stall, but if you reved it real slow it would rev up. So it was basically imposible to drive. Turned out to be the egr valve itself. Got it runnin good and sold it before somethin else broke on it.
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: 22re stalling under throttle [Re: yotaman7] #821293 06/27/07 03:19 AM
canuck Offline
Starving for fuel. Change fuel filter.
Keep the Shiney Side up. Support our troops.
Re: 22re stalling under throttle [Re: canuck] #821294 06/27/07 05:19 AM
Frank Torres Offline
no codes...
x2 on fuel
Low fuel pressure?
...weak fuel pump or clogged filters.
good luck
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: 22re stalling under throttle [Re: Frank Torres] #821295 06/27/07 03:56 PM
fuel filter is ok. still need to check fuel pressure.
dosen't seem like an egr problem to me, but i will block it off an see if it changes.
it acts exactly the same whether tps is plugged in or not. it is entirely possible that the tps is bad, but i don't think it's the only problem.
-matt
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6208 MB (Peak: 0.7022 MB) Data Comp: Off Server Time: 2026-05-29 15:00:01 UTC
