2004 TJ - Lift and Tire options
#821308
06/26/07 09:52 PM
Hello all;
I'm looking for confirmation that the following combination will fit my 2004 TJ Sport. I want to use a Skyjacker Standard 2.5" Suspension Lift Kit with Nitro Shocks, Jeep« MOAB Wheels with 5 on 4.5" Bolt Pattern in 16x8 Size & 5" Backspacing, and 32" tires. Will this all fit, and what else should I watch out for?
2004 TJ Wrangler Sport
Re: 2004 TJ - Lift and Tire options
[Re: bradford_johnson]
#821309
06/27/07 08:02 AM
According to some of the responses to my post where I'm looking to use a 2" lift and want to put 32's on everyone says they'll fit. I would watch out on the backspacing of the wheels, too much and you may stick out too far from your fenders. I know in MA you cannot stick out farther than 4" I think.
2004 TJ "X" - 6cyl.|5 speed|2.5" Skyjacker Lift|Skyjacker Nitro Shocks|Chaparral 33's|Cragar Soft 8's
#821310
06/27/07 08:40 PM
i have the same lift, and use 31's. wish i got 32's but oh well. so yes 32's will fit...dont know about the backspacing..
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
[Re: tcoff]
#821311
06/27/07 08:49 PM
Thanks....Did you use new pinon gears for the larger tires?
#821312
06/28/07 04:11 PM
nope eveything is still stock...3.07 gears d35 in the rear..i was playing it safe with the 31's. what axel's are you running?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-07 07:29:19 UTCValid HTML 5 and Valid CSS
