Vehicle Speed Sensor #821330 06/27/07 12:54 AM
celticta2s Offline OP
Sorry if this has been posted before. I did a quick search and found allot on speedo cables. Anyways I have a 94 ext cab v6 3.0L w/ an electronic speedometer.
My speedometer stopped working and I get a code of i believe 42, vehicle speed sensor. Where is it located? On the tail, transfer case, or (?)? Is there anyway to check and see if this is the problem before I buy a new one? Oh ya, the cruise control stopped also. Does the vss control the cruise control?
Thanks
1994 X-Cab V6 Auto 4X4 (3VZ-E/A340H)
Re: Vehicle Speed Sensor [Re: celticta2s] #821331 06/27/07 01:11 AM
4Crawler Offline
It is screwed to the t-case, near the rear output flange, passenger side of the case usually. Has wires attached to it.
Re: Vehicle Speed Sensor [Re: 4Crawler] #821332 06/27/07 01:52 AM
Thanks.
Is there anyway to test it?
Re: Vehicle Speed Sensor [Re: celticta2s] #821333 06/27/07 02:08 AM
4Crawler Offline
I imagine there is a testing procedure in the Factory Service Manual, see the '93 link at the top of this forum. Nor sure if that covers the electronic speedo or not.
Re: Vehicle Speed Sensor [Re: celticta2s] #821334 02/11/08 08:26 PM
The sensor and gear assembly were both bad.
My cruise control works again!
Speedometer sensor part# 8318135051
Gear sub-assy, speed part# 3340339315 (this is a 20 tooth gear)
Make sure you give the parts person your v.i.n., to make sure you get the correct gear. They told me that my truck should not have a 20 tooth, until they entered my v.i.n.
I figured I would post an update, even though I fixed it about 7 months ago. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Vehicle Speed Sensor [Re: celticta2s] #821335 02/11/08 09:44 PM
V
v8yota Offline
was there a test for it or did you just take a chance and change it,,,,i am having the same problem
Re: Vehicle Speed Sensor [Re: v8yota] #821336 02/12/08 12:17 AM
G
Greg_Canada Offline
http://www.marlincrawler.com/htm/transfercase/tcase_ac.htm#vss
Marlin crawler sells a VSS for $59.... much cheaper than the dealer.
89 4Runner
Re: Vehicle Speed Sensor [Re: v8yota] #821337 02/29/08 04:39 AM
Yeah, It's in the 1993 FSM.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6214 MB (Peak: 0.7037 MB) Data Comp: Off Server Time: 2026-06-22 03:46:16 UTC
