22re Valve install #821410 06/27/07 04:24 PM
Kaptain Offline OP
I just got all of my engine components back from the machine shop and apparently my head (EB stock head) failed the pressure test on the # 1 cylinder. They said that both valves were bent? Weird... I told them I'd take care of it.
A little background > I blew a headgasket a few months ago and decided to rebuild the bottom end. The Headgasket blew between the number 3 and number 4 cylinders. The engine ran great before hand and I'm certain the valves weren't bent at this point. The only thing that was odd was the amount of carbon buildup on the number 1 cylinder.
Anyway, I have a fresh rebuild kit from EB ready to go in.. including a new set of stock valves. > I was under the impression that these could just be dropped in without any other work. I've done some research and discovered that 'lapping' compound or machine work needs to be done.
Is this really necessary? If so, where can I get this and how is it done?
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: 22re Valve install [Re: Kaptain] #821411 06/27/07 05:36 PM
OOP'S Offline
Yes, at the least, lapping and that depends on the valve seats condition.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 22re Valve install [Re: OOP'S] #821412 06/28/07 06:49 AM
trythis Offline
If your valves were bent, is there also a possibility that the valve guides are worn from three point contact of a curved valve stem sliding through a straight tube?
Re: 22re Valve install [Re: Kaptain] #821413 06/28/07 08:35 AM
kewlynx Offline
Kap, start around page 9; that'll give you some idea of the lapping process.
Head rebuild
This is out of the FSM that's sticky'd here btw.
**ubi apis- ibi salus**
Re: 22re Valve install [Re: kewlynx] #821414 06/28/07 12:27 PM
Kaptain Offline OP
Head rebuild
Thanks guys, I know what I'm doing now... I don't think I'll have much trouble since the head is less than 2 years / 20k miles old. Plus it's already been magnafluxed and cleaned.
93' Toy xCab
Re: 22re Valve install [Re: Kaptain] #821415 06/28/07 03:42 PM
engnbldr Offline
>>>*Lapping is something we do as a final check to fit, and then only very lightly. A properly machined fresh seat will lap itself in operation as the valve rotates when running.
One thing to remember is checking the fit. We use a wide black marker pencil and coat the valve face. Press it against the seat and rotate the valve 1/4 turn back and forth to create a mark.
It is important to not rotate completely when checking, or any high spot on the seat will create a nice even circle in the paint marker.
Set the valve in the guide, use a short piece of 5/16ths ID rubber hose over the stem of the valve, this helps give a good grip for lapping if you don't have a lapping stick handy.
A lapping stick is just a short shaft with a suction cup on the end, those kinda sorta work, I like my rubber hose trick better.
If you get a clear thin mark 360 degrees on the valve face, good to go. If the mark is very wide, have the seats recut.....*EB
*Beats the he** outa me!....*LOL**...
Re: 22re Valve install [Re: engnbldr] #821416 08/22/07 04:50 PM
Kaptain Offline OP
Thanks to all... I used the EB's method to lap the valves which worked quite well.
She's all back together and running great (less than 1000 miles on it so far). It pulls alot harder and has a perfect power band for highway driving. I hardly have any trouble holding 65+ with 37's and 4.88 gears.
22re
Bored 40 over
EB rebuild kit
EB 268 Cam
2 inch exhaust
ARP head studs
93' Toy xCab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6222 MB (Peak: 0.7136 MB) Data Comp: Off Server Time: 2026-06-07 06:03:34 UTC
