Page 1 of 3 1 2 3
Keep blowing fuel pumps #821417 06/27/07 04:36 PM
Scerb Offline OP
I've had the same fuel pump since I bought the truck and have never had problems with it. The other night I was on a trail and it just died. Replaced the pump and all was fine for about 30miles and the same thing has happened again. I haven't actually confirmed that its the pump yet this second time, but its doing the same exact thing so its gotta be.
The fuel filter is about a year old, but I am gonna replace it today. The first pump had a pressure regulator down to about 3psi, but I took that off when I put the second pump in so thats not whats killing them.
Coincidence that two in a row died? I can't think of anything that would continually kill carb'd pumps, I've never even heard of one dieing before now.
Thanks,
Scerb
Re: Keep blowing fuel pumps [Re: Scerb] #821418 06/27/07 05:41 PM
ZUK Offline
What brand are these? Checker lifetimes? <img src="/forums/images/graemlins/scared.gif" alt="" />
mostly stock
Re: Keep blowing fuel pumps [Re: Scerb] #821419 06/27/07 05:51 PM
TinyTruck Offline
its a carb thing, they just suck dink
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: Keep blowing fuel pumps [Re: Scerb] #821420 06/27/07 07:31 PM
stock87 Offline
A couple things come to mind.
#1 what's the condition of the eccentric on the nose of the camshaft? If it's loose or wobbly, I bet that could make them die.
#2 is the vent hole on the bottom plugged? In the FSM it says the pump arm should lock if you block that hole, so I'm guessing if it's blocked it will rupture some internal gaskets.
#3 check the return line for blockage. I'd say get rid of the FPR, but you already did. Again the FSM says blockage in any of the lines should lock the pump arm.
Maybe?
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Keep blowing fuel pumps [Re: stock87] #821421 06/27/07 11:22 PM
Scerb Offline OP
These are factory toyota pumps outa parts trucks. Got a couple left before I gotta start paying for'm <img src="/forums/images/graemlins/scared.gif" alt="" />
Stock87, you brought up some good points about something being clogged. I was in mud about 20min before the 1st one died, but not before the 2nd one died. Maybe the return line got plugged somehow, idk and I don't look forward to finding out.
And TinyTruck, carbs suck your moms dink.
-Scerb
Re: Keep blowing fuel pumps [Re: Scerb] #821422 06/28/07 02:43 AM
TinyTruck Offline
scerb, how bout we race 2wds to settle the carb thing.......mine will win
1988 YOAT "Stumpy"
Re: Keep blowing fuel pumps [Re: TinyTruck] #821423 06/28/07 03:25 AM
Scerb Offline OP
Well thats not fair, you got lot more weight reduction than me,,, [rust]. Then again you weigh enough to makeup for it.
Re: Keep blowing fuel pumps [Re: Scerb] #821424 06/28/07 04:23 AM
TinyTruck Offline
hey, ive also got almoast 100k miles more than you. Mine really only has about 10lb rustlightening. also I weigh about 120lbs more than you.
but mine will still win
1988 YOAT "Stumpy"
Re: Keep blowing fuel pumps [Re: TinyTruck] #821425 06/28/07 04:26 AM
kewlynx Offline
Sounds like you two need to stop talkin' smack and get together this weekend. <img src="/forums/images/graemlins/pfft.gif" alt="" />
TAKE PICS! <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Keep blowing fuel pumps [Re: kewlynx] #821426 06/28/07 05:55 AM
Scerb Offline OP
OKJ!!!! Kewlynx pays for speedign tickets!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-05-29 23:55:30 UTC
