Page 2 of 3 1 2 3
Re: Keep blowing fuel pumps [Re: Scerb] #821427 06/28/07 06:08 AM
kewlynx Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" />
Just don't hurt anything or anyone, or out to the shed we go!
Really, be careful and have fun! <img src="/forums/images/graemlins/pfft.gif" alt="" />
**ubi apis- ibi salus**
Re: Keep blowing fuel pumps [Re: kewlynx] #821428 06/28/07 06:21 AM
Ganoid Offline
Not sure if this applies to Toyota or not but some mfr's put a spacer between the mounting surface and the fuel pump so that the lobe on the little cam that runs the pump wont over compress the arm. I don't remember what kind of vehicle it was but some one I know was eating up fuel pumps pretty fast. So fast that he actually always carried 1 or 2 spares until one day he figured it out when he was looking under the hood of some one else's truck and then that was the end of his fuel pump woes. Its worth looking into?
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: Keep blowing fuel pumps [Re: kewlynx] #821429 06/28/07 06:45 AM
Scerb Offline OP
-wtfs this thread have to do with the 2wf anywa6s!!!?!?!!!\\
Thats a good thought bout the spacer, but its lasted 3 yrs without one so i dojnt really think thats the problem..
And kewlynx, its always safe.
Thanks,
Scebr
Re: Keep blowing fuel pumps [Re: Scerb] #821430 06/28/07 07:04 AM
kewlynx Offline
Actually with the spacer, I would think it would affect the tension the fuel pump lever would have against the lobe (sorry, can't remember the proper term)
It's weird you're going thru them tho'-- I replaced my first one at 192K; diaphragm died. My NAPA replacement is still goin' strong.
Re: Keep blowing fuel pumps [Re: Scerb] #821431 06/28/07 08:06 AM
stock87 Offline
Thanks,
Scebr
Actually considering it was pushing against the FPR AND you weren't running the spacer I'm amazed it lasted as long as it did. The spacer is going to keep the pressure down some anyway (just plain less tension = less pressure I assume). You may have gotten lucky with a fairly robust one that put up with it for a while, the other spares may not be so forgiving. I think I'd go back to the spacer, and the FPR since I hear the Webbers get really pissy without it.
Also, spares are never as good as new. 23100-39336, 65.52 @ 1sttoyotaparts.com, comes with new gaskets and spacer...
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Keep blowing fuel pumps [Re: stock87] #821432 06/28/07 02:59 PM
Scerb Offline OP
Well heres the thinker:
The first pump I blew was the newer style pump which I have never seen have a spacer. The 2nd pump I blew was an older style pump. Maybe the 1st one blew from old age and the 2nd one blew because it was supposed to have a spacer? I've never seen a spacer on a pump, but I have also never seen an older style pump installed. Maybe only the older ones come with spacers??
-SCerb
Re: Keep blowing fuel pumps [Re: Scerb] #821433 06/28/07 03:12 PM
myyota Offline
You need to have the spacer between the head and fuel pump or you will damage the fuel pump.
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
Re: Keep blowing fuel pumps [Re: myyota] #821434 06/28/07 11:55 PM
eightyeight Offline
scerb you sure your old pump didn't have a spacer?
it's entirely possible that it fell out while we were changing it on the trail at 2 in the morning by cell phone light...
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Keep blowing fuel pumps [Re: eightyeight] #821435 06/29/07 12:44 AM
yotaman7 Offline
Ha ha, thats awesome!
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Keep blowing fuel pumps [Re: Scerb] #821436 06/29/07 03:04 AM
kewlynx Offline
Both my 83 and my 86 have the fuel pump spacers.
Sounds like ya lost it during the trail fix.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6420 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-07-16 03:24:31 UTC
