Re: Keep blowing fuel pumps
[Re: Scerb]
#821427
06/28/07 06:08 AM
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" />
Just don't hurt anything or anyone, or out to the shed we go!
Really, be careful and have fun! <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: kewlynx]
#821428
06/28/07 06:21 AM
Not sure if this applies to Toyota or not but some mfr's put a spacer between the mounting surface and the fuel pump so that the lobe on the little cam that runs the pump wont over compress the arm. I don't remember what kind of vehicle it was but some one I know was eating up fuel pumps pretty fast. So fast that he actually always carried 1 or 2 spares until one day he figured it out when he was looking under the hood of some one else's truck and then that was the end of his fuel pump woes. Its worth looking into?
90 Xcab V6 3.0 Rebuilt/Balanced P/P w/OS valves Downey Hdrs,Jacobs Ign 5.29's,Tru Trac+Lockright 4"TG SAS+Rear Kit on 35's (DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />) www.performancecylinderheads.com
[Re: kewlynx]
#821429
06/28/07 06:45 AM
-wtfs this thread have to do with the 2wf anywa6s!!!?!?!!!\\
Thats a good thought bout the spacer, but its lasted 3 yrs without one so i dojnt really think thats the problem..
And kewlynx, its always safe.
Thanks,
Scebr
[Re: Scerb]
#821430
06/28/07 07:04 AM
Actually with the spacer, I would think it would affect the tension the fuel pump lever would have against the lobe (sorry, can't remember the proper term)
It's weird you're going thru them tho'-- I replaced my first one at 192K; diaphragm died. My NAPA replacement is still goin' strong.
[Re: Scerb]
#821431
06/28/07 08:06 AM
Thanks,
Scebr Actually considering it was pushing against the FPR AND you weren't running the spacer I'm amazed it lasted as long as it did. The spacer is going to keep the pressure down some anyway (just plain less tension = less pressure I assume). You may have gotten lucky with a fairly robust one that put up with it for a while, the other spares may not be so forgiving. I think I'd go back to the spacer, and the FPR since I hear the Webbers get really pissy without it. Also, spares are never as good as new. 23100-39336, 65.52 @ 1sttoyotaparts.com, comes with new gaskets and spacer...
[Re: stock87]
#821432
06/28/07 02:59 PM
Well heres the thinker:
The first pump I blew was the newer style pump which I have never seen have a spacer. The 2nd pump I blew was an older style pump. Maybe the 1st one blew from old age and the 2nd one blew because it was supposed to have a spacer? I've never seen a spacer on a pump, but I have also never seen an older style pump installed. Maybe only the older ones come with spacers??
-SCerb
[Re: Scerb]
#821433
06/28/07 03:12 PM
You need to have the spacer between the head and fuel pump or you will damage the fuel pump.
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
[Re: myyota]
#821434
06/28/07 11:55 PM
scerb you sure your old pump didn't have a spacer? it's entirely possible that it fell out while we were changing it on the trail at 2 in the morning by cell phone light...
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod. -'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
[Re: eightyeight]
#821435
06/29/07 12:44 AM
Ha ha, thats awesome!
[Re: Scerb]
#821436
06/29/07 03:04 AM
Both my 83 and my 86 have the fuel pump spacers.
Sounds like ya lost it during the trail fix.
