3.5 Stalling #821648 06/27/07 10:33 PM
A
all we'll drive Offline OP
My 3.5 Trooper is stalling when idling. Idle seems low ~500rpm, Seems to only happen when pulling away from a stop light. I just cleaned the ERG last week, but it was fairly clean: No CEL, and newish spark plugs. The RPM's do not hunt, they are just low.
Any ideas on what to try next?
Adam <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: 3.5 Stalling [Re: all we'll drive] #821649 06/28/07 12:10 AM
A
Amigo-2k Offline
my guess is it is the intake manifold gasket.
Re: 3.5 Stalling [Re: Amigo-2k] #821650 06/28/07 12:15 AM
A
So, spray the intake manifold down with carb cleaner and see if the RPM's increase?
Any other ideas?
P.S. it has 85k miles on it.
Thanks Adam <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 3.5 Stalling [Re: all we'll drive] #821651 06/28/07 10:56 PM
W
Wayne Offline
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: 3.5 Stalling [Re: Wayne] #821652 06/29/07 06:42 PM
A
Thanks, great right-up!
No intake leaks and I tried cleaning the MAS. I also noticed that there is a fair amount of slack in the throttle cable. Is that normal?
Re: 3.5 Stalling [Re: all we'll drive] #821653 07/11/07 07:22 PM
Bigpoppax2 Offline
Just because the carb cleaner didn't show anything means nothing. I tried using propane with a rubber hose to find where mine was leaking. I never found any leaks, but finally my CEL came on and I got the tale-tell code saying I was running lean.
This will almost always confirm an IMG problem when accompanied by IMG type symptoms. Mine were cracked bad. Both sides.
Joe
Re: 3.5 Stalling [Re: Bigpoppax2] #821654 08/09/07 01:55 AM
A
I gave up and took it to a shop. They said that it was the ERG Valve...broken open. When I cleaned it it seemed to have plenty of spring in the valve. Any ideas? Should I just buy a new one?
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6178 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-07-13 12:31:05 UTC
