As the subject line says my Toyota PU isn't being too cooperative. It is a 86 4x4 PU with a 22R.
For about the last week I have had to crank the engine about ten seconds before it finally starts. This is not a consistant problem, however it seems more prevelent when the engine is cold, buty will also do it sometimes when it is warm. With that in mind I took a can of carb cleaner and cleaned the carb. I also threw a new air filter on for the grins of it. After that it started easy. I didn't take it for a test drive at the time because I was only having starting problems. Anyway that night (I work night shift), I leave to go to work and it starts up fine. I drive down the road to the first stop sign and it dies when I come to a stop. For whatever reason it will not idle. This continues on for several miles and stop signs. The truck runs good going down the road, no problem at all, it just dies every time I have to stop, (very inconvenient). I finally get on the highway and drive the last 15 miles to work without any stop signs. When I get the to work, it is idleing fine. I had the same situation on the way home this mornining. It would not idle until I got all the way home. The only thing I can figure is that this is a choke problem. Now I admit that I have not really taken a good look at it this morning, (I am about to go to bed), and hopefully when I get up this afternoon, I will have some answers to this problem from all of you nice folks. By the way, the carb does have 250,000 miles on it. I have a Napa rebuild kit sitting on my workbench, however I have to go out of town for work in a few days and I don't want to tear apart the carb and take the chance of not getting it together before I have to leave. It would drive me nuts knowing the truck is not running while I am gone, plus I like for my wife to have a second vehicle if need be.
Any suggestions where to start would be greatly appreciated.
