Properly inflating bigger tires #821816 06/28/07 11:41 PM
Rodayo Offline OP
Now that I've added new bigger tires to the Rodeo, how do I determine the proper inflation?
Thanks!
- Jim
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Properly inflating bigger tires [Re: Rodayo] #821817 06/29/07 01:19 AM
4xToy Offline
since wheel width, load weight, and other factors all come into play the best way is time consuming but it is the most accurate way is to draw a line of chalk across the width of the tire about 2 inches wide. set your tire pressure at what you think is about right. Then drive it down the road and back. Check for rubbed off chalk. This exposes what part of your tire contacts the ground the most. Worn off on the center= too much pressure, worn on the outsides= too little pressure. Ideally you want all of the chalk to be gone.
-Chad
Re: Properly inflating bigger tires [Re: 4xToy] #821818 06/29/07 01:46 AM
Richard Saylor Offline
I'll agree with the above, except for the drive it down the road. You really wanna test this on a flat level surface. The road can have all sorts of imperfections that can invalidate your test. No need to drive it either. Just roll it so that the tire makes at least one revolution. Then check it and adjust until you get a nice even wearing.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Properly inflating bigger tires [Re: Richard Saylor] #821819 06/29/07 02:20 AM
4xToy Offline
Yeah by "the road" I should have specified level, smooth road. I don't like the roll down your driveway method, cause one revolution didn't work well for me. Maybe my chalk was too tough.
-Chad
Re: Properly inflating bigger tires [Re: 4xToy] #821820 06/29/07 02:51 AM
But most roads have a crown in them to help water get off the roadway faster.
84 Honda XL185S
Re: Properly inflating bigger tires [Re: Richard Saylor] #821821 07/23/07 08:24 PM
chasespeed Offline
Use a parking lot
Chase
Re: Properly inflating bigger tires [Re: chasespeed] #821822 07/23/07 09:13 PM
94rodeo Offline
I just inflate my tires to the recommended psi listed on the tires.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: Properly inflating bigger tires [Re: 94rodeo] #821823 07/23/07 09:41 PM
If you look on the tires, it says max psi. Only time you'll want to run that psi is if you're at the max weight rating for the tire.
84 Honda XL185S
Re: Properly inflating bigger tires [Re: Richard Saylor] #821824 07/29/07 02:35 PM
A
all we'll drive Offline
I just keep letting the air out until I can get traction back. If it pops off the bead, you let too much out <img src="/forums/images/graemlins/notooth.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6282 MB (Peak: 0.7311 MB) Data Comp: Off Server Time: 2026-07-14 10:48:37 UTC
