Shifting Problems #822032 06/30/07 02:28 AM
josh_jeeper Offline OP
Need Help i have a 89 jeep cherokee and i cleaned my engine with degreaser and the hose and now the engine wont shift out of first. When driving its fine to start out but will not shift the rpms just keep going up. But when i let off the gas and get on it again it acts like its in neutral and wont move till it hits 2500 rpm. Any questions what i might ahve got wet and where the wiring for the transmission is .
Josh Stefani
Re: Shifting Problems [Re: josh_jeeper] #822033 06/30/07 03:21 AM
BobRowe Offline
The first thing I would do would be to start the engine (outside) and let it idle for about 30 minuts, in order to get everything heated up and dried out. Then take it on a 10-15 mile road trip to exercize the tranny and gears. Then re-assess the situation and see what works and what doesn't.
Re: Shifting Problems [Re: BobRowe] #822034 06/30/07 03:26 AM
already tried that and didnt work. Any other ideas
Josh Stefani
Re: Shifting Problems [Re: josh_jeeper] #822035 06/30/07 04:38 AM
4x4Wire Offline
The engine control unit should be on the passenger side fender well in the engine compartment.
Also, there are a couple of cables by the air intake that you need to check. One is the throttle cable and it does pop out of the holder and will cause the rpms to increase if not firmly seated.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6001 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-07-13 03:41:27 UTC
