anyway to test the VSS #822054 06/30/07 05:35 AM
V
v8yota Offline OP
is there anyway to test the vss,,,my speedo is not working,,,once in a great while it will jump up to 20 mph and then back to zero,,,my cruise also does not work,,i am guessing because of the speedo,,,,,,i checked and cleaned all wires at the vss and the gauge cluster,,,,can it be the speedometer itself,,is there any way to test that,,,,,any suggestions would be great,,,i do not want to spend over $200 for a new vss and that not be the problem
Re: anyway to test the VSS [Re: v8yota] #822055 06/30/07 07:35 AM
rednekbean Offline
well a year and model really help as second gen's are manual speedo and third gen are electric..and such...
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: anyway to test the VSS [Re: rednekbean] #822056 06/30/07 02:40 PM
V
v8yota Offline OP
it is a 93 and it is an electric speedo
Re: anyway to test the VSS [Re: v8yota] #822057 06/30/07 02:58 PM
OOP'S Offline
Have you looked at the FSM that is sticky at the top of this BB. It should tell you how to run a test on it.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
P.S. download the FSM on to a disc, you never know when it might go away.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: anyway to test the VSS [Re: v8yota] #822058 06/30/07 06:22 PM
rednekbean Offline
From what i have seen of the electric speedo just before it goes out the needle will be real bouncy and not consistent than it will be off more and more till nothing.
Re: anyway to test the VSS [Re: rednekbean] #822059 07/05/07 11:04 PM
celticta2s Offline
I just went though the same thing. Goto page 12. #6 from this link. It tells you how to test the VSS.
1993 FSM
Re: anyway to test the VSS [Re: celticta2s] #822060 07/05/07 11:33 PM
V
v8yota Offline OP
wondering what you came up with when you did the test,,,,,,,,also that test is for an automatic
Re: anyway to test the VSS [Re: v8yota] #822061 07/13/07 10:07 PM
celticta2s Offline
I found that my VSS was bad and replaced it. Mine is on an auto, so if yours is a manual... I don't know. Look in the 1993 FSM under the manual transmission and see what you come up with.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6191 MB (Peak: 0.6970 MB) Data Comp: Off Server Time: 2026-10-24 23:51:46 UTC
