Driveline Noise #822183 07/01/07 03:28 AM
racerfan120 Offline OP
Good day! I have a 87' pickup, and whenever or at least most of the time, when I shift from 1st to 2nd, 2nd to 3rd, I hear a clank, or almost a tink noise if that helps. Is this normal? I checked the u-joints and I don't THINK <img src="/forums/images/graemlins/wink.gif" alt="" /> they are worn beyond what is acceptable. From what I know the sound is from undernieth me. Also when going down the freeway, or at higher speeds, when I let off the throttle I feel it clunk, same when I apply throttle. Normal or is something worn out?
Re: Driveline Noise [Re: racerfan120] #822184 07/01/07 03:44 AM
OOP'S Offline
The "tink" noise is a u-joint going south. It is a very distinct noise and it is most always a U-joint.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Driveline Noise [Re: OOP'S] #822185 07/01/07 03:49 AM
W
Whizkidder Offline
X2. Classic description of a u-joint impending failure. I'd put the truck up on jackstands, neutral, no park brake, and play with the driveshaft(s) until I found the culprit.
Re: Driveline Noise [Re: racerfan120] #822186 07/01/07 04:00 AM
JackKnife Offline
Another common area where this sound comes from is the slip joint. It wouldn't hurt to add a little grease and see if the sound goes away.
Re: Driveline Noise [Re: racerfan120] #822187 07/02/07 01:56 AM
P
PETE_YK Offline
I've heard it could also be the pressure plate???
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Driveline Noise [Re: racerfan120] #822188 07/02/07 04:31 PM
mqm Offline
I had the same clunk noise at light throttle. I replaced the ujoints and that made no difference, i kinda suspected that there was some slack in the rear third member. So a few months ago i swapped my stock 4.10 units for a set of stock 4.88's. Now i have no clunk, only buttery smooth power transfer from the engine to the road.. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Driveline Noise [Re: mqm] #822189 07/03/07 12:43 AM
W
walktastic Offline
on my old truck i had the same problem and it drove me nuts! but i found out on mine that it was the slip joint. of course, i found that out after having every clutch part known to man replaced.
V6 pickup 4x4, 385,000 miles and still ticking
Re: Driveline Noise [Re: mqm] #822190 07/04/07 03:05 AM
cktoy Offline
I had a similar noise plus a bad pinion seal.when I put the aussie in I tightened up the pinion shaft nut and replaced the rear ujiont for good measure.sounds much better now and not as much vibration.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6194 MB (Peak: 0.7014 MB) Data Comp: Off Server Time: 2026-10-22 00:09:21 UTC
