Page 1 of 3 1 2 3
The ? To Replace Clutch--Which way pull engine or tranny? #822379 07/01/07 08:03 PM
G
guvtrooper Offline OP
89 5-speed. This is my first post. I will try to keep it short. I have read the clutch posts. It looks like it is very difficult to pull a transmission-tranfer case on your back, by yourself. I thought I saw a post few years back that pulling the engine would maybe be easier even if it takes more time. I don't need to do any transmission repair, just clutch. I have the time and would like to give it a try, either way. I have done minor work on the car; fuel pump, clutch slave, brakes. I have a Chilton manual. Thanks for any advice you have.
Getting old is not for sissies.
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822380 07/02/07 05:10 AM
A
acy76 Offline
I'd pull the transmission. It was not what I'd classify as "very difficult". Two floor jacks on hand will help. Much less to disconnect this way. This advice applies to the 4-cylinder Trooper.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: acy76] #822381 07/02/07 06:25 AM
paulevans76 Offline
IIRC, you have to pull the trans to pull the engine...or maybe that's only if you don't disconnect the diff brackets and drop the differential down. <img src="/forums/images/graemlins/confused.gif" alt="" />
88 Troop - Posing yard art
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822382 07/02/07 05:42 PM
TatoHead Offline
I did a clutch job on my 88 Trooper 4-cyl/5 speed back in 2004. As I recall, it wasn't terrible, but I had a couple guys help out. I don't recall having to drop the exhaust out of the way, which is the part I hate because of the fragile nature of exhaust bolts and connections.
I make it a habit on any clutch job to get an early start and call the machine shop in advance to make an appointment to get the flywheel surfaced. Nothing worse than dropping the trans and then find out it will be a week to get the flywheel ground. I know that some just leave the flywheel in and change the disk / pressure plate only, but it seems like whenever I've cut that corner the clutch will eventually shutter.
Good luck!
1993 Trooper
"Purple People Eater"
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: paulevans76] #822383 07/04/07 08:08 AM
G
Thanks for the replies. I hate to sound so stupid. I don't even know what IIRC is. The book I have says you can change the clutch by pulling the engine if you suport the tranny. Thought I would try it as a learning experience. I will be doing this without help. The posts I have read look like lots of guys are getting some serious learning by taking out the tranny. I realize it will take more time but its easy time compared to dealing with that tranny on my back alone. Any more suggestions folks might have would be appriecated. I will drop a post to let you know how it works out. Thanks
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822384 07/04/07 08:16 AM
paulevans76 Offline
IIRC: If I Remember Correctly <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822385 07/04/07 08:33 AM
randii Offline
It is possible to pull the motor and leave the tranny, but there is WAY more involved to pull the motor and leave the tranny, than there is to pull the tranny and leave the motor.
I recommend not doing either job on your own unless you have an engine hoist (for the motor) or a transmission jack (for the tranny). Isuzue bits are HEAVY!
Randii
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822386 07/04/07 04:01 PM
88SuperTrooper Offline
Get a jack ( not a bottle jack... ) and pull the tranny. Otherwise you might as well just rebuild the engine while you have it out that far. Get the flywheel resurfaced and replace the slave cylinder. and just put the tranny back in after your all finished. If you dont intend to rebuild the engine, dont bother pulling it.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: guvtrooper] #822387 07/05/07 03:05 PM
marcucci Offline
For what it's worth, I found this tranny to be a real PITA (pain in the ass) to pull. There's a lot to disconnect, no more than with any other 4WD, but getting the integrated tranny & tcase out was a challenge. Getting to the top bolts was a pain, too. I finally fuond that going at it through the shifter hole, after lowing the transmission a little, with a LOT of extensions, worked pretty well. I've done it twice now and hope that my current clutch lasts a long time!!!
I would definitely get a purpose-built tranny jack from Harbor Freight or somewhere else and have a friend help when dropping it. I would also recommend the factory shop manual as well.
Re: The ? To Replace Clutch--Which way pull engine or tranny? [Re: marcucci] #822388 07/09/07 09:09 PM
F
Fujisawa_Rob Offline
Also, a block of wood under the oil pan and a floor jack help to tilt the rear of the drivetrain down (with crossmember removed) to give better access to upper bellhousing bolts. watch the distributor (v6) on the firewall!
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6423 MB (Peak: 0.7678 MB) Data Comp: Off Server Time: 2026-06-07 06:01:40 UTC
