Looking for some advice on buyin a 89 with a 3.4 swap #822451 07/02/07 01:05 AM
I
irish_ROCKS Offline OP
http://www.pirate4x4.com/forum/showthread.php?t=585605
Its high time to get rid of my 91 3.0
What kinda questions would ya ask bout a swap like this??
Opinions ....would it be a maintenance nightmare???......
I want another xcab v6 and dont really have the funds for a tacoma.............
Thanks Y'all
irish kicks ASS!!!!! ;-p
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: irish_ROCKS] #822452 07/02/07 02:23 AM
Adam F Offline
Wiring/electrical is the biggest thing I'd check.
97 4R, stock, daily driver
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: Adam F] #822453 07/02/07 06:06 PM
I
the quality of it? or try n figure wat he did n double check ?
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: irish_ROCKS] #822454 07/02/07 08:13 PM
Adam F Offline
Just make sure the harness is clean, no bad splices, butt connectors, exposed or corroded wires/connectors, no check engine lights, gauges work, etc etc
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: Adam F] #822455 07/02/07 10:23 PM
dcg9381 Offline
Make sure it's passed inspection recently.
Make sure it has it's OBD-II port availalble and I'd strongly suggest scanning it for codes. IF the diagnostics aren't available or don't work, you'll be screwed when it has issues.
22REturbo.net
1988 4Runner
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: irish_ROCKS] #822456 07/03/07 02:06 AM
kewlynx Offline
To add to this, ask if he's got any documentation of his work, and as said, ESPECIALLY the wiring.
FWIW, a few folks here have done this swap, so we've got it here. We also have an FSM for the 3.0 in this section and the 3.4 FSM over in the Taco section if you ever need it.
How many miles on the swap, and what tranny is behind it?
**ubi apis- ibi salus**
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: irish_ROCKS] #822457 07/04/07 04:01 AM
RONNY Offline
check with the folks at downeyoff-road.com the have a lot of info on several different swaps. got a i buick 3.8 that would be better choice i believe by what i read on thier site ,go to the engine conversions manual section. electrical is not as bad as u would think.i just want to keep my 4 cyl. but if you know anyone interested i have buick lesabre my wife just wrecked bought it with 50k miles has 70k now excelent motor
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: RONNY] #822458 07/05/07 06:39 AM
CORunner93 Offline
Check the electrical.....as said over and over in earlier posts. That and the exhaust are really the only big fabrication items.
Check to make sure all the wire connections are soldered and covered with heat shrink plastic....not crimp connectors....crimp connectors will fail eventually.
Make sure he has both O2 sensors in the exhuast.
Take an ODB-II tester with you (or drive the truck to an parts store like Advance Auto, they will do it for you) and hook it up...check for ECU recognition and codes.
Make sure he didn't do a hack job on the exhuast either....good welds and that it is supported properly.
Look closely under the hood and make sure everything was relocated and/or installed securely' all wires are tape wrapped and securly tied down. Make sure he has the correct EVAP box (should be a square-ish black box) and, that it is hooked up.
Other than that, make sure everything works...tach, gauges...the motor idles around 750 and is smooth....there is no reason the truck shouldn't run like it came from the factory with that motor.
If the guy did a nice job, you'll love the truck....I love my 3.4L '94 4Runner.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: RONNY] #822459 07/05/07 01:57 PM
Red_Chili Offline
Toyota Section Staffer
check with the folks at downeyoff-road.com the have a lot of info on several different swaps. got a i buick 3.8 that would be better choice i believe by what i read on thier site ,...
Could not disagree more strongly- and Downey is not up on the 3.4, only old school swaps.
Check the exhaust crossover work, it can be a real nightmare. A motor swap can be simple and clean, or it can be a real hack job, it all depends, but is usually fairly obvious on close examination.
If it is a 3.0 to 3.4, most of it will probably be decent. +1 on pulling the codes, and beware if the guy has reset anything. Emissions laws may require a state inspection and certification, mine did; wasn't a huge deal in Colorado though especially since Mike Caskey did such an obviously clean job.
-Bill
Re: Looking for some advice on buyin a 89 with a 3.4 swap [Re: kewlynx] #822460 07/05/07 07:12 PM
I
thanks adam an everybody chiming in with wiring check tips
kewlynx 50k on engine an tranny not sure bout the tranny I need to call the guy today
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6390 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-07 04:47:44 UTC
