1976 jeep cherokee wagoneer commando rearend #822523 07/02/07 04:46 AM
droptines Offline OP
a friend of mine owns one, the housing just to the side of the chunk area is broken.where could he find another and is it very costly?any help greatly appreciated.
Re: 1976 jeep cherokee wagoneer commando rearend [Re: droptines] #822524 07/02/07 05:18 AM
BigJim Offline
Ok so you have a broken part. From the description I'd guess part of the pumpkin that holds an axle tube is broken?
If that is the case you are SOL! You need another rear end.
For that age of a vehicle I would be looking for a used axle with the same gear ratio in it that would swap right in there.
Re: 1976 jeep cherokee wagoneer commando rearend [Re: BigJim] #822525 07/02/07 06:34 AM
thanks,do you have any idea about what one would cost?are they hard to come by?
Re: 1976 jeep cherokee wagoneer commando rearend [Re: droptines] #822526 07/02/07 04:20 PM
BigJim Offline
First thing is to do the "turn the wheel trick" and find out what gears are in there.. Then start looking.
I think that Jeep still has the NARROW rear end in it. Around here they show up almost weekly on craigslist.org.
$2/300. would be a respectable price for one that is in Ok condition.
If you get the WRONG gears you must then take the new one and the old one to someone that can change out the gears for you. $$$$! Getting the correct gears enables a direct swap!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-06-17 04:18:17 UTC
