Generic O2 Sensor OK to Use??? #822578 07/02/07 05:11 PM
Tygger Offline OP
Looks like O2 sensors for my car are about $50 to 75ea. I found generic ones for about half that price, $25, but it doesn't look like they come with the harness.
I dont mind cutting and slicing my old harnesses from the bad sensors, but will these generic sensors be any good???
1997 Isuzu Rodeo S 4WD
Re: Generic O2 Sensor OK to Use??? [Re: Tygger] #822579 07/02/07 05:36 PM
Gizzy42 Offline
In my experience they are kind of hit and miss. I used them on my old mitsu p/u (only 1 wire) and one of them always read a little low. The one I replaced it with worked fine though.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Generic O2 Sensor OK to Use??? [Re: Gizzy42] #822580 07/04/07 04:04 PM
88SuperTrooper Offline
X2 Gizmo, Ive never had any luck with them either, Especially Bosch one's.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: Generic O2 Sensor OK to Use??? [Re: 88SuperTrooper] #822581 07/05/07 05:57 AM
Gizzy42 Offline
I put the Bosch o2 sensors with factory plugs in my rodeo a few months ago and they are working fine. My mileage went up a bit after replacing the originals that had 100k miles on them. I've never been a fan of Bosch but havent had problems with their stuff on the rodeo. The ones I had in the mitsu were some off brand I think.
--Dave
Rear No-Slip Locker
Re: Generic O2 Sensor OK to Use??? [Re: Gizzy42] #822582 07/05/07 05:06 PM
Tygger Offline OP
I just found Denso oxygen sensors online for $28. They don't come with the connectors, but I dont mind cutting and splicing my old ones.
Are Denso sensors any better than bosch?
Oxygen Sensor
Brand: Denso
DENSO REPLACEMENT OXYGEN SENSOR, FRONT, LEFT -- Front Left UNIVERSAL Oxygen Sensor, 1 Required Per Vehicle, Reuse Your Old Connector, Electrical Installation Required, Non-Returnable, Sold Individually
Re: Generic O2 Sensor OK to Use??? [Re: Tygger] #822583 07/05/07 05:16 PM
mlclark Offline
Isuzu Moderator
It is not the brand that is the big issue here. It is the cutting/splicing of the connector. Since the O2 sensor is a resistance sensor, things like splices, loose splices, corrosion at splices, different length wires, ect all affect what the ECU sees in the end.
Michael
Re: Generic O2 Sensor OK to Use??? [Re: mlclark] #822584 07/05/07 06:27 PM
Tygger Offline OP
Oh, I didnt know that... So are all O2 sensors basically the same except for the harness and fit? eg. if it fits in the hole, then its ok to use?
Re: Generic O2 Sensor OK to Use??? [Re: Tygger] #822585 07/05/07 08:58 PM
mlclark Offline
Isuzu Moderator
Weeeellll...I am not going to go as far as to say that. I would suspect that most O2 sensors are able to provide a reference voltage to the ECU and that range of reference is probably similar across most makes/models, but...I really don't know. Your ECU uses O2 sensors to adjust the a/f ratio and to check up on the function of your cats. If something is not right you might see low gas mileage, over heated cats or just a string of error codes.
What I am worried about is the discussion above is about 1-wire sensors, not the 3/4-wire heated sensors you need. I am actually surprised that you found generic heated sensors.
In the end, you can do whatever you want, but don't forget that if it does not work, you are going to be out an extra $100 for using the cheap sensors and you will still have to buy the correct ones.
Good Luck,
Michael
Re: Generic O2 Sensor OK to Use??? [Re: Tygger] #822586 07/06/07 12:02 AM
Gizzy42 Offline
Denso is a good brand, they are the only spark plugs I use and wouldnt have a problem with using their o2 sensors.
If you go with splicing in the old connectors I would suggest soldering the splices and covering with heat shrink tubing, you can get it at radio shack pretty cheap (remember to slide the tubing on the wire BEFORE soldering together). That would give you the best connection and least corrosion worries. Also make sure you dont get wires swapped around.
--Dave
Rear No-Slip Locker
Re: Generic O2 Sensor OK to Use??? [Re: Gizzy42] #822587 07/06/07 06:31 AM
Tygger Offline OP
Thanks for the info.
I'll prob. order the Denso ones, but does anyone know why there are multiple different Denso sensors for different locations?
The Parts Bin
These dont come with the connectors, but the prices are all different.
NP2341000 $28.13
NP2342071 $58.96
NP2344206 $79.91
NP2344210 $61.36
NP2344212 $59.35
NP2344700 $69.60
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6337 MB (Peak: 0.7417 MB) Data Comp: Off Server Time: 2026-06-07 04:41:38 UTC
