Page 1 of 3 1 2 3
T-Case ... need options... #822731 07/03/07 03:37 AM
trav Offline OP
I've determined that I need lower t-case gears. What options are out there? I've already got tera lows in there... what else can i do?
1998 Isuzu Rodeo -- slightly modified.
Re: T-Case ... need options... [Re: trav] #822732 07/03/07 04:24 AM
strawmyers Offline
Isuzu Moderator
Swapping the 'Zu tranny/t-case out for a 700R4/D300 with aftermarket 4:1 gears has been done. How low are you wanting to go? Dual 'yota cases has also been done behind the automatics.
Sean Strawmyer
Re: T-Case ... need options... [Re: strawmyers] #822733 07/03/07 01:18 PM
RobG Offline
and dual Isuzu cases behind the manual have been done as well.
-Rob
Re: T-Case ... need options... [Re: RobG] #822734 07/03/07 04:09 PM
L
Locomigo Offline
and there are those that have stacked another 'zu case (auto tranny divorced tcase) behind their manual, for lower gearing.
Not to mention a marlin crawler setup, although that is a replacement of tranny from the 'zu to a yota
You have lots of options Trav.
Re: T-Case ... need options... [Re: Locomigo] #822735 07/03/07 04:15 PM
lttlbddy Offline
Just curious, what is your axle gearing?
Re: T-Case ... need options... [Re: lttlbddy] #822736 07/03/07 11:05 PM
94rodeo Offline
With the skills you have and work that I have seen on your truck, I would just try the dual isuzu case set up and see if that is low enough for you. I picked up an auto t case for $100 and the metal, bushings etc involved mostly came from a scrap bin ran under $50. The aluminum welding/tig was all done by my brother. I am sure someone around the fire house can tig for you. The spendy part was the drive shafts for mine.
Troy
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: T-Case ... need options... [Re: 94rodeo] #822737 07/04/07 01:24 AM
Rodeo Clown Offline
My buddy stuck a divorced np205 behind his stock setup. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: T-Case ... need options... [Re: Rodeo Clown] #822738 07/04/07 01:20 PM
RobG Offline
seems like a lot of overkill and weight to shove behind a stock setup, you won't ever come close to needing all that strength. there are probably lighter divorced cases with better low range you could apply this same principle too.
-Rob
Re: T-Case ... need options... [Re: RobG] #822739 07/06/07 06:03 AM
Rodeo Clown Offline
This is true, but he got a good deal on it and now he never has to worry about it again. <img src="/forums/images/graemlins/smile.gif" alt="" /> But there are definitely lighter t-cases that can be had.
Re: T-Case ... need options... [Re: Rodeo Clown] #822740 07/11/07 03:45 AM
trav Offline OP
Humm... humm.... Theres some options out there. I'm very intregued with this dual isuzu t-case option. I have a manual, so your runing an auto t-case with it? humm... any kind of write up on this bad boy?
ps- i'm running 5:38's
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6393 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-07-15 02:06:50 UTC
